hv oil pump killed drive gear
OK my car as lost oil pressure it has a new hv oil pump put in about 2000 miles ago the drive gear is the stock one with a 140,000 miles i think this is the problem what you guys think..
we can "guess"....but you will have to pull intake manifold to check the status of the drive gear.
initially you can drain oil and remove the oil level sensor to see if the pick up tube fell off.
also if there is metal shavings on the oil plug...that is a sign "something" is wearing
