Build my 1200 budget plz
Painted headers will rust out quickly in Chicago. This is an investment, if you want a return on your times and the money you spent, spend it on parts that are worth it and will last you a long time. Otherwise you will be buying cheap parst that won't work as good and will have to buy the real parts shortly down the road. It will cost you twice as much to do it 70% now!
I'm from Chicago, and use my TA in the winter. I have coated Pacesetters, not painted and even those started rusting within 2 years. The collectors are pretty damn rusty already. Pacesetters, have great fitment though, and I got mine for super cheap slightly used from Florida.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I dont want a hot cam i would like to do a 396 w/ le2 heads with a custom cam, and rear mount turbo , or ls1 that i would have built before dropping it in and putting in a rear mount turbo, why get a ls1 car when I can put it in this and not have to worry about emissions. I dont feel like going through selling this, I would trade + cash for ls1 though but that wouldnt happen b.c ppl w. there ls1 dont want to trade for lt
My plans is DD car that can hit 13.00 or close to it, Somewhat of street/drag car, would like to get near 350-370rwhp.
I thought up until now most of the recommendations have been straight forward and somewhat thoughtful and helpful. For your goals and budget the hotcam kit fits the bill. If your car truly does have a cam in it, it should already be turnin 13's. For $1200 you couldnt even buy the machine work needed for a 396.
My advice to you would be as it is to anyone. Doesnt matter how much power you make or how you make it, if you can't get it to the ground it ain't ****. Build your cra suspension first, get everything tied in so it can handle the power and keep it to the ground. With it being an auto I would stall it with a QUALITY converter anywhee from 3000-3600 since you are DDing it. Pair that with 3.73's out back and you will swear you have a new car......from there I would (in your case) work on the headers and exhaust, and then start adding to the engine.
#32
Yea I was just saying the 396 with le2 heads for the future. I am wanting it at least want to put down 350-370rwhp that could put down a 13.00 or if better would be great until then I want to start with doing some prep work. The ss rear end is the rear end I believe the gears so it would be wat a 3.42? I want an SS hood b.c they r the best looking hood for the camaro IMO and I hate this stock z28 hood that has like this 1in bondo mark plus spider webbin going on
#33
#34
what are the key suspension stuff, lca and tq arms but isnt there clearance issues with certain headers? I think this round I am going to end up with 1.6rr and LT/ y pipe and a tq converter and a starter since im haveing starter issues. Then round 2 in about 2m will be lca, tq arm, subfrme conn, and ss hood.
But I may be able to pick up so lca on tuesday if speed inc still have there sale, are non adj umi lcas worth it/ good ?
Im also going to try to squeeze out cash for 160 tstat and bbk ud pulley
Then obviosly get tune after everythng
#35
I recommend that you read a lot of the threads on this site, do a ton of research and please get some baseline numbers. And I would recommend doing all the FREE mods.. good luck on your build.
#37
ima do some weight removal when the time comes, Q? while i am thinkin of these rr if I go to 1.6rr do i need to change the pushrod are the pushrod same length? or lifters or can I keep them stock for a while?
I have some xtra cash outside the budget to do this starter and hopefully lca's if you guys recommend the lca
and i will get the 160 tstat since i think mine is bad newayz
#38
So far as LCA's are concerned the stockers are stamped steel and they are not boxed you can put a screwdriver in the eyelet and twist it all the way around with one hand. It doesnt have to be an adjustable LCA, ANYTHING is better than stock. If you do not plan on lowering the car those will be fine. If you plan on lowering it you should get lca relocation brackets and adjustable lcas. You should get a new TA and subframe connectors as well.
To answer your other Q's RR's are just replace, no need to change anything else at the moment. You will probably have to clearance your vlave covers. I wouldn't waste my time on the UD pulley at all. I have seen more harm than good due to te fact they undercharge the alternator, so unless you change that pulley too, its not worth it.
#39
To answer your question on how to find out if you have tg converter just press the brake all the way down and slightly press on the gas and just watch and see how high you can rev it. I think stock you can rev it up to 1500 rpms
#40
and if it goes past that then it isnt stock? how do u clear the valve covers? The car has aftermarket struts, there are a set of umi subfrc and adj lca with brackets for sale on craig list near me should i get them or a new set? Thx for the help guys
