rotating a keyless crank
Old Jul 8, 2011 | 09:37 PM
food nd cars's Avatar
Default rotating a keyless crank
What are you guys using to rotate the crank when the crank hub is not on? I've got an old crank socket, but the key is missing on LT1's.
Old Jul 8, 2011 | 09:43 PM
pro94lt's Avatar
prybar on the flywheel or pull the injector fuse and bump the starter
Old Jul 8, 2011 | 09:57 PM
how bout if its on an engine stand w/o the flywheel?
Old Jul 8, 2011 | 09:59 PM
whytryz28's Avatar
Can you bolt up the balancer?
Old Jul 8, 2011 | 10:03 PM
I can and but i would prefer not to, because when it comes time to install the timing cover i'm gonna have to rent a puller again.. I'm thinking of getting a crank key and temporarily using it so i can use my old crank socket? anyone do this? What size crank key should i be looking for?
Old Jul 8, 2011 | 10:49 PM
Puck's Avatar
If you get a key, you might as well take your stock hub to a machinist to be cut for it as well. It will be dirt cheap.
Makes no sense to install it just to turn the engine over and remove it again.
Old Jul 9, 2011 | 12:14 AM
so everyone just uses their crank hub or flywheel?
Old Jul 9, 2011 | 12:20 AM
whytryz28's Avatar
I just turned mine by hand using the balancer, wasn't hard at all.
Old Jul 9, 2011 | 12:35 AM
yeah. I've been using a grade 8 bolt in place of the stock crank bolt to turn it... Im just afraid of stripping the threads.
Old Jul 9, 2011 | 12:42 AM
Big Al's Avatar
Use the stock bolt and washer, and a 1/2" drive socket as a spacer. Be sure the plugs are out. You can only turn it clockwise.
Al 95 Z28
Old Jul 9, 2011 | 12:48 AM
Al 95 Z28
Im not following on the 1/2'' drive socket.. haha
Old Jul 9, 2011 | 01:01 AM
tbag_skywalker's Avatar
Sounds like he's saying to get a socket big enough, like a 1/2" drive socket, to cover the threads of the crank bolt and space it out so that you don't damage the threads.
Old Jul 9, 2011 | 01:14 AM
Wouldn't that weaken the strength of the bolt? having less threads grabbing the crank instead of more threads?
Old Jul 9, 2011 | 01:27 AM
whytryz28's Avatar
Use you're best judgment, obviously you wont be using a deep set socket. Also with the plugs out it will turn over relatively easy.
Old Jul 9, 2011 | 07:26 AM
SS RRR's Avatar
Village Troll
I just put a few washers on the crank bolt so it doesn't bottom out before turning the assy. The torque spec on that bolt is something like 75ft lbs. If it takes that much force to rotate your assy. then something is wrong.
Old Jul 10, 2011 | 09:45 AM
nitrous2fast's Avatar
a degree wheel bolted to the crank would work..
Old Jul 10, 2011 | 11:54 AM
the socket trick works wonderfully
