Project Reaper 2.0
Old Oct 14, 2011 | 02:44 PM
  #261
Jpack's Avatar
Nope, it is put to bed for the season. Going to do the required safety, rearend, etc starting soon.
Old Jun 7, 2012 | 02:36 AM
  #262
bizerk1's Avatar
Here is link for, ride a long in jpack car after we put my cars engine in. I know bad camera shooting but it is hard to hold the phone still in this car, lol. Would get better video next time.
http://www.youtube.com/watch?v=llARR...ature=youtu.be
Old Jun 7, 2012 | 05:21 AM
  #263
Boosted Firehawk's Avatar
so whos engine is in whos car? Its a bit tough to understand that when I thought Clayton built his engine.
Old Jun 7, 2012 | 09:53 AM
  #264
94LT1TA6spd's Avatar
Damn, that thing seems pretty mean!!
But you are right, the camera work left something to be desired!!
Old Jun 7, 2012 | 11:32 PM
  #265
Gear Rower's Avatar
i didn't know Jason owned a Z28, i remember he had his 96 SS forever, then sold it and bought an LS1, and now of course a 5th gen.
Old Jun 8, 2012 | 12:01 AM
  #266
bizerk1's Avatar
clayton racing did build his engine, I just said I went for that ride after we put my engine in my car
Old Jun 8, 2012 | 06:27 AM
  #267
Jpack's Avatar
You are thinking of the wrong guy. This is the forum I got the car from.... http://www.Z28.com/forum.php
Old Jun 8, 2012 | 06:32 AM
  #268
Jpack's Avatar
My engine is a Clayton racing set up. That video is in my car running a three gear pull with no nitrous and no traction on drag radials.
Old Jun 8, 2012 | 12:40 PM
  #269
So jim what do u think ur cars runs on nutz?
What should it do on spray?
What does your engine consist of?
Old Jun 8, 2012 | 01:36 PM
  #270
Jpack's Avatar
Right now I have no idea until I get my 28" tall tires on so I don't hit the limiter going through the traps. I run a th350 and have 4:10 gears and will hit limiter before hitting the traps. I have an accel dfi computer and harness to get on the car as well so I can hit over the 7k rpm. I need that on so i can spray it with a 250 shot. Car isnt ideal right now in its current set up to get a good dyno or track run. The car should have low 9's , maybe....maybe high 8's if I can get it to 60' good off the trans brake and shot out of the hole.
Engine wise, its a 12.5:1 with custom CP pistons, highly worked over heads and big hyd roller cam.
Trans is a rossler th350 rmvb with a fti converter @4200 on the brake.
Currently i know that I bury the speedo at 7k rpm and it comes really quick. The video the guy posted had my speedo pegged past 150 and it stuck.
Old Jun 12, 2012 | 10:40 AM
  #271
Turnin20s's Avatar
Are you planning a gear change to run on spray then? If so what gears?
Nice setup BTW
Old Jun 12, 2012 | 12:46 PM
  #272
Camaroking1996's Avatar
What is your exhaust setup? Sounds badass!
Old Jun 12, 2012 | 01:27 PM
  #273
Jpack's Avatar
Gears will stay as is, 4.10 but will have a 28" tire on the rear. Spray the car once the accel dfi is in and running so I can spin the rpm I need. Right now the nitrous is off the car until I plumb everything the way i want it.
The exhaust is just a loudmouth with a sweet thunder. It is loud as hell in the car and driving around at 3k rpm at 55 mph is annoying as hell. The video doesn't really give a good sound clip for just how loud it really is.
The build is really nothing exotic or crazy. The only thing really custom was the pistons that started as one offs, but now can be purchased through Clayton. This set up even uses stock heads just heavily worked and a stock intake worked over by me. Other than the th350 the car rolling around is very Streetable and no surge or issues at low speed, low rpm. The converter in the car from FTI is honestly the best converter I have ever had in any car I have ever owned. I believe that is the key to the drivability around town. But if you put your foot in it, all hell breaks loose. It hits hard off the trans brake.
Once I get it to the track again and get the time and mph, I will see where I am at with the car and see what improvements need to be done to get me where I want to be. Last weekend i dialed in the suspension a little better for na. Once I get it all dialed in and make a full pass it will be a one and done. Still don't meet nhra requirements, but should be ready next season. Depends on if the wife let's me dump more into the car. She keeps asking when I am going to finish working on hers to get it where she wants it.
Old Jun 13, 2012 | 12:03 AM
  #274
Turnin20s's Avatar
Wow, how high do you plan on spinning the motor on spray through the traps?? Not saying that you can't do it, just more curious than anything.
Old Jun 13, 2012 | 08:25 AM
  #275
Jpack's Avatar
Should see about 7600-7800 rpm. Once I get the other computer system in and finish the nitrous I can get the car on the dyno and find out a little more on how far we can push the set up. Right now it is kind of on the back burner right now with working during the day and helping run a bodyshop after work. I have the car with a safe tune in it, but letting Corey Clayton dial in the dfi once installed. He has more knowledge of that software and nitrous than i do.
Old Jun 13, 2012 | 12:48 PM
  #276
Turnin20s's Avatar
Thanks for the response, and good luck with the rest of the build And I know exactly what you mean about finding time to work on your car, we have way too many projects around here
Old Jul 17, 2012 | 06:35 PM
  #277
Jpack's Avatar
Just adding a few updated pics....
Old Jul 17, 2012 | 07:04 PM
  #278
95mysticta's Avatar
Congrats on getting a article in the magazine i remember seeing it when reading through not to long ago.
Old Jul 17, 2012 | 07:11 PM
  #279
Love the new stance! Any new updates?
Old Jul 17, 2012 | 08:27 PM
  #280
Jpack's Avatar
Thanks. Nothing really new. Gave the car a real good buff and detail. Been too busy with work and now part owner of a custom car and bodyshop. Spend a lot of time up at the shop building some nice cars when I'm not at my day job.
