What CHEAP mods can I get to finish bolt ons?
Old 07-12-2011, 07:33 PM
  #41
boostedlt1's Avatar
Originally Posted by LSWHO
I am hoping to pay said guy to make me some SFCs too! I have cash...!
I have the full amount for DRs so those are soon as well.
My only concern is the crappy LPP True duals with that torque arm. But I'm all for a torque arm too.
I'd still like to aim that drivers side exhaust pipe up a bit too. I'm considering getting rid of the mufflers soon too. Maybe putting some straight under the axle exhaust. I think the mufflers are restrictive.
alright, i can definitely hook you up on the sfc's
for the torque arm if you just drop your car off i'm sure i'll be able to fab up a cross member to clear the TD's.
aren't the mufflers straight through? or do the bottle neck down inside? i can't quite remember. i guess it's a good thing i only tacked them on huh?
Old 07-12-2011, 07:54 PM
  #42
Mystery Bird's Avatar
Originally Posted by boostedlt1
you should definitely get a torque arm... i know someone that could make you one..
Someone make me one, I'm still running the stocker.
Old 07-12-2011, 07:56 PM
  #43
LSWHO's Avatar
Sweet. I won't ask you to do any under car work until summer is over. I know I'm anti car work right now.
As far as the mufflers the OD is the same as the rest of the piping so they definitely choke down inside. I was thinking of cutting the tack welds next time I run to free up some colorado hp.
Old 07-12-2011, 08:10 PM
  #44
boostedlt1's Avatar
yeah i hate working on my own car right now. but i've still been doin work for people even though my driveway is like 180 degrees
Old 07-12-2011, 08:38 PM
  #45
itSSlowZ28's Avatar
of course you could go full suspension. from what i've actually read about what you have, tq arm, front a-arms, and springs to name a few. then there are the little bs things like deep tranny pan and trans cooler. i can't really think of anything else, maybe just go ahead and jump on the 58mm tb if you know your going to need it later. everyone says you don't NEED it, but i don't see how it would hurt
Old 01-20-2012, 11:20 PM
  #46
01ssreda4's Avatar
Originally Posted by T/ALT1
You could buy an aluminum driveshaft to replace the steel stocker, that will make the car quicker and only costs about $150-$250 depending on the brand. Buy Tunercat and you can fine tune the PCM for more HP. Add n2o and youll pickup a second for $500 thats the "bang for the buck".
No a DS will not make your car "quicker". At least not enough to notice and make it worth spending the money.
Old 01-20-2012, 11:24 PM
  #47
lt1slowz28's Avatar
you alright?... thread has been dead for 6 months
Old 01-20-2012, 11:48 PM
  #48
FAD2BLK93's Avatar
LS1 mod > ram air...maybe check into the chris1313 ram air tunnel mod as well...picked up 2 tenths myself for 200 bucks, search it. I also dont see that u have the TB cooling mod.
Old 01-23-2012, 11:14 AM
  #49
sweetbmxrider's Avatar
Originally Posted by Lawhead
Mystery on here has home ported heads and so Do I he has track numbers and hopefully soon i'll have some AI or LE are not the only one making LT1's fast
True that yo
This guy knows his stuff. Lighter parts do not make your car quicker.
Old 01-23-2012, 07:27 PM
  #50
2cat95ta's Avatar
Sway bars for a track car or the Xtreme sway bar for a 1/4 mile car
Old 01-24-2012, 03:52 PM
  #51
ahritchie's Avatar
http://www.summitracing.com/search/B...Oxide-Systems/
Old 01-24-2012, 07:11 PM
  #52
bufmatmuslepants's Avatar
Weight reduction. I pulled 400lbs out of my car without spending a dime. 400lbs = .4 off the quarter mile.
Old 01-24-2012, 07:19 PM
  #53
ZFreie's Avatar
You have a much nicer version of my setup lol For what the car isnt it sure is quick
Quick Reply: What CHEAP mods can I get to finish bolt ons?
