Golen 396 lt1
Old Jul 20, 2011 | 10:06 AM
1slow94z28's Avatar
Karl Ellwein.
1badzee's Avatar
Originally Posted by Nastyc4
Your tuner is a morron. Ask an engineer who designs MAFs. The screen helps keep debris out and most importantly straightens airflow which allows for more accurate readings. IF you gained anything the same hp can be gained from a tune. Removing it skews the readings and probably leaned out a little. Again anyone who reccomends it is a complete morron.
Old Jul 20, 2011 | 10:15 AM
RamAir95TA's Avatar
Originally Posted by nastyc4
ive had no dealings with golen but it is possible that the customer asked to reuse his parts? Bent pushrods are also common from reving too high. but if i were a builder and someone asked to build something i didnt think would hold together i wouldnt do it.
Exactly.
Old Jul 20, 2011 | 10:41 AM
TAEnvy's Avatar
well its a business and if the professional reccomends going with one thing and the customer wants something else the customer is always right.
I see this all the time I recommend something to the customer and they ignore me, well thats on them. If they have the internet and think they are an expert and wont listen to me that's them, and since im in business to profit I wont turn away work like this. Ill explain to them no warranty ad its their choice. If I turn it away theyll go down the street and someone else will make the money.
I can understand him not wanting to loose a while engine over a crank. I do believe I read if you put a cast crank in certain motors he wont warranty it.
I know alot of the vette guys use him so they may have more insight, but I would have no problem using him, I would listen to his recommendations on build specs and be clear on warranty circumstances.
Putting a bottom end together isnt magic, it comes down to good machine work and proper clearances.
Old Jul 20, 2011 | 10:59 AM
djjab57's Avatar
I'm not trying to bash you but a ORY is "off road Y pipe" witch means no cats, I guess what your saying is your just going to buy an ORY and add cats ?????
Old Jul 20, 2011 | 11:23 AM
SS RRR's Avatar
Village Troll
BTW... if you go with the shop I suggest you will actually get a build sheet for your specific application unlike most of the clownhouses who get their blocks built in mass quantities. Good luck trying to get them to answer any specific question you may have with your block...
Old Jul 20, 2011 | 11:26 AM
bigz28man's Avatar
thanks guys, you have been a huge help. As far as with cats I'm running high flow cats on the car now. I'm not sure of what is a good set up will be. when I decide on the motor, I just want to make sure that I'm doing it right....thats all. As far I know now, stock MAF sensor, and no cats. My thinking was in the next year or two after the motor is in, to put a super charger on the motor, I guess that I was trying to say with the 600 rwhp. Sorry everyone, I am very new at this and learning as I go along.
Old Jul 20, 2011 | 11:30 AM
RamAir95TA's Avatar
Building a motor for N/A and then "slapping a supercharger" on it later doesn't work, since there are certain guidelines you should follow when building a bottom end built for boost. Fortunately you admit that you're new to this and it sounds like you're willing to learn, so that in itself is a great start.
Old Jul 20, 2011 | 11:36 AM
fex77k's Avatar
Originally Posted by 1slow94z28
Karl Ellwein.
Old Jul 20, 2011 | 12:02 PM
BALLSS's Avatar
I bought a Golen 383 short block. My $02 is go forged. Yes the Eagle cast is cheaper....but then you always get what you pay for
Karl Ellwein is arguably one of, if not the best builder out there. He is a one man shop and attention to detail is top notch.
...and building a NA motor now and then adding a power adder later is not a good idea. REALLY think about your end goal and develope a solid plan to get there. Your driveline (includeing clutch) need to be addressed with the power goals you have in mind
Old Jul 20, 2011 | 12:08 PM
speed_demon24's Avatar
Is that why no new MAF's have screens on them? So what exactly is your tuning experience since you claim to know more than someone does this for a living. Hell when I was only making 27xrwhp I left the car strapped down and swapped out descreened MAF ends and picked up 3rwhp, and the a/f didn't budge. And what the hell kind of air filter are you running that would let something big enough in to be caught by the MAF screen?
Old Jul 20, 2011 | 12:40 PM
  #32
BALLSS's Avatar
it is my understanding the MAF screen "primary" purpose is to stabalize the air flowing accros the sensors to allow for more consistant readings...aka data the pcm sees. Descreening it one would assume flow is increased "x" (but debateable as to how much). While the screen also would prevent debris from entering and possibly causing damage to the very thin wire sensors that would be a sceondary benefit but as one poster mentioned the size of that debris would be quite large and assumebly bigger than a air filter would allow to pass.
So I assume some tuners feel the increased flow yields "X" power more than screened.
One tuner I have high regard for, Ed Wright, feels screen should be left in because the MAF readings are more consistant. I am speaking about B/F body LT1 MAF
Old Jul 20, 2011 | 02:49 PM
  #33
moehorsepower's Avatar
I can tell you that we did a test on the dyno on this theory. We dynoed a car with the stock maf, then right there removed the screen, Yes it did make a couple of more horsepower but that was because it leaned it out, Thats my experience with the de screening of the MAF. Myself, I would leave the screen in place..
Old Jul 20, 2011 | 05:25 PM
  #34
96capricemgr's Avatar
Care to support this statement?
Far as the MAF descreen thing, it depends on the intake tract. You have a bend right before the MAF and the screen IS a good thing. If the tract is straight and smooth on the approach then they are not needed.
If you want to do this well the first thing you need to do is scrap your plan and start over with actual meaningful research this time instead of looking at a magazine article.
My car is unusually fast for what it is and what is done so I have a good idea what actually works and IMO the vast majority of your plan is very poor.
Have you ever driven a powerful car? People throw around numbers like 4-5-600rwhp without ever having driven any more than 300rwhp and have no clue exactly what it is they are discussing and how hard it would be to handle or use on track much less on the street.
Old Jul 20, 2011 | 11:19 PM
  #35
TAEnvy's Avatar
I dont understand how you can assume you have a pretty good understanding of what works and what doesn't. You've had what 1,2 different setups? AI.
I doubt you are well versed in what works because many of the things you say dont work continue to put down good numbers (cc306s and LE stuff for instance)
Old Jul 21, 2011 | 12:34 PM
  #36
BALLSS's Avatar
Dwayne
Karl’s reputation and ability’s as a “builder” do not need any statement of “support” from me other than my opinion as stated. His knowledge of the LT1 platform is extensive and he has been an active drag racer in his LT1 powered B-body. His knowledge on what combination of parts and abilities of building motors is well documented. Like other builders he can put together a package the customer wants and also advise on what he would chose or do. In the end it is the customer’s decision on what path to take.
Instead of making condescending and assumptive comments of the OP’s? Just state wtf you prefer and leave it to that.
There is more than 1 qualified builder, including Golen, the OP can go to. If you have another opinion on who than say so. Just bashing his comments without offering any alternate suggestion unfortunately is your style.
OP. Builders like Golen offer a range of builds to fit within budgets. Whoever you chose understand that lower $ often means the parts are not = quality. Especially in cast vs. forged. Head & Cam combo will play a big part in end performance #’s. You can spec what components you want or consult with the builder on what their opinions are. IMHO I would choose one who is experienced in the LT1 platform. As mentioned there are advantages of using a “local” builder especially if issues arise after the build.
Advanced Induction and Lloyd Elliott are both well-known and offer very good head/cam combos. Karl & Golen both can build you a motor with those components.
You need to determine what your end performance goal is and $ resources to achieve that goal are. This board will offer “opinions” which is all my comments are. Consulting directly with a builder of choice will yield more definitive info with which you will ultimately have to make a decision on.
Old Jul 21, 2011 | 12:49 PM
  #37
Lawhead's Avatar
CC306 never puts out power........its LT1 law
Old Jul 21, 2011 | 02:46 PM
  #38
SS RRR's Avatar
Village Troll
After all the mouthing you've done about my pile I am hoping your setup delivers. Don't disappoint me.
Old Jul 21, 2011 | 02:52 PM
  #39
Lawhead's Avatar
You and me both
The motor has already delivered in another car. It's all on what I put around the motor if it doesn't turn out like planned lol
Old Jul 21, 2011 | 09:04 PM
  #40
I did not tell the guy what to use so those of you bashing me for my recommendation can shut up already.
I told him he did poor research and to start over with his plan.
You have guys with wildly underperforming engines built and rebuilt(because they were junk) telling you what they think works. A positive review means a happy customer. What you need for meaningful research is to figure out which happy customers are SMART enough to know they actually got something good and who is just too mentally challenged to recognize they bought substandard parts.
