Golen 396 lt1
Old Aug 6, 2011 | 10:21 AM
  #61
bigz28man's Avatar
Ok so i decided that I'm going with the 396 lt1 from Golen. Chad at Golen stands by his work and I'm fan of that....I will hope for the best when the motor is complete. So now I have decided that I want a weekend warrior car, but yet still be able to take it out on a nice day with my girl. I have a question about the exhaust. So I'm running hooker long tubes on this motor, note that these long tubes have no o2 bungs...what should I do? Should I run the long tubes back and have a true duel exhaust setup, or should I have a ORY, to a catless exhaust system (running slp loudmouth I ) now. also should I run O2 senors or just keep them off?
Old Aug 6, 2011 | 10:30 AM
  #62
SS RRR's Avatar
Village Troll
I would advise against it unless your cam is too much for the O2's to handle. In that case the only way to safely run w/out them is to have the car dyno tuned by someone who knows exactly what they're doing. Do you have emissions concerns where you live?
Old Aug 6, 2011 | 11:24 AM
  #63
Lawhead's Avatar
You do realize how loud that Loudmouth 1 is going to be right???
Old Aug 6, 2011 | 12:18 PM
  #64
bigz28man's Avatar
Ok, seeing that the headers I do have have no O2 sensor bungs, where would the holes be drilled at (I do know that a hole just past the collector on each would be drilled but where else?
Old Aug 7, 2011 | 12:13 AM
  #65
Nastyc4's Avatar
just look at the headers online like kooks and ar / lg etc and see where it is. usually well behind the collector so it gets a good sample flow from each primary
