I need help on my comp 2.5 clutch install
Ok i got my competition 2.5 clutch installed and i went to start it and as its cranking over and i can feel the clutch grabbing when i have the pedal all the way down and it made a light squealing noise.. so i turned it off right away...what could cause this?
Maybe the slave end of your clutchfork is being pushed too far and its hitting the spinning pressure plate? I know first hand that would cause the metal shavings and an obnoxious screech.
I could think of two things that would cause that
You make sure the pressure plate is tightened down enough? If its loose and sticking out enough, it will hit the fork when the fork is being pushed towards it.
Do you have an adjustable master cylinder? If that's the case you might just have to back it off a bit to prevent the rubbing.
I rolled around with a ground down clutchfork for a while, then at some point in my clutch swap adventures, I bought a new OEM fork and it worked fine without needing to be ground.
97REaper, the tips of the fork that make contact with the throwout bearing wear down over time, as you can see in SS_RRR's pic, and that's atleast part of what causes the fork/pressure plate rubbing. Basically, when those tips wear down enough, the fork is naturally positioned slightly closer to the pressure plate which causes the rubbing.
As long as the pressure plate is sitting flat on the flywheel, all you've gotta do is grind down your fork a bit.
