is a gu5 drum brakes carrier the same a gu5 disc brakes?
need a differential for my 94 z28 with disc brakes.. found a 94 v6 gu5 car with drum brakes.in the junkyard that I can get the.differential out of.for.30 bucks,.are.they the.same?
Got it and installed it , its not the posi type with springs and Crap before but it'll work for now... now I have bigger problems, after I got everything finished I hopped in and threw it in drive and took off... it went to 3500 and shifted into 2nd and my rear end locked up and car wouldn't move.. put it in reverse and it moved, put it back in drive and 1st was fine then hit 2nd and a bunch of clanking and grinding from the tranny and alot of jerking.. tranny was just built with solid servo's, race bands and everything so Idk Wtf is going on now... gonna check it out tomarrow..
