What's a good Cam to put in a LT1 for loud idle and 140mph open throttle
Old 08-02-2011, 10:01 PM
Flyguy.Camaro's Avatar
Default What's a good Cam to put in a LT1 for loud idle and 140mph open throttle
just curious, please post up links where I could buy it. need the whole kit.
Thank you ~FLY
Old 08-02-2011, 10:11 PM
speed_demon24's Avatar
First
Old 08-02-2011, 10:16 PM
ElkySS's Avatar
can we PLEEEEEEEEEEEEEEEEEEEEEEEASE get a facepalm smiley?
Old 08-02-2011, 10:20 PM
Moderator
BizZzatch350's Avatar
Cc304.
Old 08-02-2011, 10:26 PM
Ls2SilverBullet's Avatar
I think this is what you're looking for:
http://kalecoauto.com/index.php?main...products_id=30
And for some loud exhaust:
http://kalecoauto.com/index.php?main...&products_id=2
Old 08-02-2011, 10:29 PM
IronOutlaw's Avatar
I'd get a 3/4 race cam but be sure to get some good race spark plugs or they will foul out. I'd also get a k&n filter and hypertech race chip. For it to be loud run some high quality straight pipes.
Old 08-02-2011, 10:31 PM
jlpz's Avatar
Originally Posted by Ls2SilverBullet
Man got to get me a set of there cross drilled brake lines...
Old 08-02-2011, 10:40 PM
lol
Yeah, the review says they are the ****
Old 08-02-2011, 11:26 PM
gregrob's Avatar
Stock with a cutout should do it
Old 08-02-2011, 11:28 PM
defaultexistence's Avatar
Wow .... Just, wow .. And welcome. eBay has the one that's loud idling at 140 ... Also look into the mustang cam mod I herd it's good to 150 and plenty loud
Old 08-03-2011, 12:30 AM
food nd cars's Avatar
pretty sure this guy is joking
Old 08-03-2011, 01:56 AM
Rabble's Avatar
For starters, you're going to need one of these
and then,
This setup for safety.
Old 08-03-2011, 02:02 AM
lt1slowz28's Avatar
post number 13
Old 08-03-2011, 02:16 AM
lethal bird's Avatar
Get a hypertech handheld tuner and pull the stock y off and your there. Hell that will prolly put you at close to 200mph with 1000hp. Then you can go take down a some zr1s.
Old 08-03-2011, 02:34 AM
Rabble's Avatar
Pish, don't listen to him, he has no idea what he's talking about. Look at his sig "SLOW"<<<<<<<<< Yeah...
Old 08-03-2011, 07:21 AM
pillarpod's Avatar
LT4 Hot Cam kit is just for you, you'll jizz when you hear it and its the best bang for the buck
Old 08-03-2011, 08:04 AM
shbox's Avatar
Not. https://ls1tech.com/forums/lt1-lt4-m...-need-s-p.html
Old 08-03-2011, 09:27 AM
pillarpod's Avatar
here is an idle clip of my Hot Cam in my '99 TA. Its pretty choppy.
http://www.youtube.com/watch?v=L79eg2zsBr4&NR=1
never mind that V3 crap
Old 08-03-2011, 09:39 AM
quik95lt1's Avatar
only thing is if you do the 140mph cam you must order hydraulic dohc mudflaps and replace your blinker fluid with hypoallergenic synthetic fluid............also replacing the exhaust with a 6.35 Volt tip is reccommended...................
Old 08-03-2011, 10:14 AM
mguidry629's Avatar
Funny stuff guys, but I think he's serious and just needs a little education on what cams do.
Yo Fly, cams don't make an engine louder, exhaust does that (or lack of exhaust). A cam might give you a little lope or chop and make it sound more aggressive at an idle, but not really "louder".
Here's a link to electric exhaust cutouts, which is what will make your car 'loud' at idle and much cheaper than a cam.
http://www.summitracing.com/search/P...haust-Cutouts/
Your other thread had some comments you really need read again. Especially the one about your car being safe enough to drive 140mph and needing the right suspension, tires, etc to go that fast.
As mentioned before, 140mph is possible with a stock car once you tune it. Most of us are not after a top speed, we're after acceleration. Most of us actually reduce our top speed by getting taller gears and tires for better acceleration.
And what do you mean by 140mph open throttle? If you really want a cam, you need to research what they do and give us some more detailed goals for your car.
Quick Reply: What's a good Cam to put in a LT1 for loud idle and 140mph open throttle
