DS header to ypipe gasket.
Old Aug 3, 2011 | 06:37 PM
ringmaster72's Avatar
Default DS header to ypipe gasket.
I have an exhaust leak on my DS header and I think I have found it. It seems to be at the back, either the weld is split or the pipe is split. My problem is I need to pull the header out so I can see where it is leaking.
So, where can I get the gasket that is between the header and the ypipe? I want a good one, not a cheap paper one.
Old Aug 3, 2011 | 08:19 PM
RamAir95TA's Avatar
Can't make any kind of judgement without knowing what your exhaust setup is. What brand of headers do you have, if any?
Old Aug 3, 2011 | 09:57 PM
The headers were already on the car when I bought it, so I am not sure of the brand. They are short headers, so I figured that it used the stock style gasket since the stock y pipe is in place.
