Neat CNC video.
Old Aug 8, 2011 | 11:10 AM
RamAir95TA's Avatar
Default Neat CNC video.
http://www.youtube.com/watch?v=O6N-G...&feature=feedu
Just saw this on YouTube and it's pretty neat to see how the whole process works. Yeah, it's from AI but it's LT1-specific, so for anyone interested in how CNC works it's pretty cool.
Old Aug 8, 2011 | 11:24 AM
merim123's Avatar
that is really neat to see. my family has been in the machine shop business for a long time on the tool side and i've seen all the drills/end mills made. It's cool to see that stuff in use. All the tools are not cheap! That end mill they are using is not a cheap item for sure. And everytime he has to re-sharpen, adds cost to it as well.
Old Aug 8, 2011 | 11:26 AM
Advanced Induction's Avatar
Smile
I had just logged online to post it.
It is the first video I've ever even made (used the free Win Live Movie Maker) & was curious to see if there were more/less shots and angles people would like to see. There are many head machining videos on youtube, but most are on low-end machinery from haas, centroid, etc. It is tough for me to judge the editing etc. since it is something I put together, programmed, and see every day. It necessarily skips forward quite a bit since each head takes so long to machine. Those transitions and captions are something to refine a bit.
As I have time I'll be making some videos of the newen CNC seat machining process, more head machining (like helical milling pushrod clearance), etc.
Thanks for the feedback!
-Phil
Old Aug 8, 2011 | 11:42 AM
ZFreie's Avatar
Thats freaking awesome! Its great seeing a machine that big moving so perfectly . I love technology some times.
Old Aug 8, 2011 | 12:04 PM
jlpz's Avatar
Very nice vid..I'd sure like to see more on how that head turns out..
Old Aug 8, 2011 | 12:16 PM
Puck's Avatar
Very cool. I especially like the automated tool changing.
Out of curiosity, due to factory tolerances I know that our heads can vary slightly in port size, shape, and flow even among identical casting numbers and dates. Are the factory heads consistent enough to use the same exact program for every head, do you have different NC programs for each casting number, or even more tedious - do you have to measure certain reference points and manually tweak programs for differences in individual cylinder head geometry?
I've taken a few machining courses, but that was on stuff like simple 3-axis CNC mills, CNC lathes, and programmable robotic arms - nothing as high end and advanced as that amazing machine.
Old Aug 8, 2011 | 01:12 PM
shbox's Avatar
LOL, like watching the Science Channel.
Old Aug 8, 2011 | 02:29 PM
speed_demon24's Avatar
It's nice to see how your heads are ported I would definitely be interested in a video showing how the valvejob is done.
Old Aug 8, 2011 | 03:27 PM
96TransAmboosted's Avatar
This should be on how its made. I remember when I thought valve grinding was bad ***.but this just blows that out orbs water.
Old Aug 8, 2011 | 06:02 PM
lt1-xjs's Avatar
Very nice CNC video of how it's done, I doubt you'll see how the valves are done but I'm sure it's done on a Serdi. And people still do this by hand, it is still an art and alot of work and will produce similar results. Cool none the less.
Old Aug 8, 2011 | 06:12 PM
ZFreie's Avatar
Wonder how many man hours it takes to hand port a set of heads....
Old Aug 8, 2011 | 06:31 PM
trilkb's Avatar
If youd like to make another video with more angles and shots, ill donate a set of heads ( im sure you dont have any ) )
Cool vid, looks like a cnc machine. I like how it changes bits, reminds me of noises that darth vadar makes
Old Aug 8, 2011 | 07:49 PM
wrd1972's Avatar
Very cool.
AI,
How many minutes to port a head beginning to end?
Old Aug 8, 2011 | 07:53 PM
Depends on the quality of the port job.
Old Aug 8, 2011 | 07:58 PM
Puck's Avatar
This X a million.
Also the material can make a big difference - older iron heads will take longer then our aluminum heads...but either way you are looking at a LOT of man hours to heavily port a set of heads properly by hand.
Old Aug 8, 2011 | 08:29 PM
merim123's Avatar
I bet there is more in programming on this then in a set of hand ported heads. That's a lot of instructions that need to be programmed at a time.
Old Aug 8, 2011 | 09:14 PM
Puck's Avatar
Yes, but the program only needs to be written from the ground up once. On the second set the hand porter is starting from scratch again...while the CNC porter can just run the program again (minus any tweaks which need to be made, like I asked about in my last post).
Old Aug 8, 2011 | 09:31 PM
Tireburnin's Avatar
This video shows that you get what you pay for. Nice equipment in that video.
Old Aug 8, 2011 | 09:59 PM
jasonisdn's Avatar
you should see and hear that beast in person. it makes the hair around your man hood stand up.
Old Aug 9, 2011 | 07:43 AM
quik95lt1's Avatar
very cool phil........ive seen CNC's running before and I've done some minor programming on ours here at work...... but never on a cylidner head...very cool!!!
