Neat CNC video.
http://www.advancedinduction.com/LTX...ccCompHead.php
Still many results & I believe I have some newer photos to add to the revised site. Lots of info up for the time being.
Out of curiosity, due to factory tolerances I know that our heads can vary slightly in port size, shape, and flow even among identical casting numbers and dates. Are the factory heads consistent enough to use the same exact program for every head, do you have different NC programs for each casting number, or even more tedious - do you have to measure certain reference points and manually tweak programs for differences in individual cylinder head geometry?
I've taken a few machining courses, but that was on stuff like simple 3-axis CNC mills, CNC lathes, and programmable robotic arms - nothing as high end and advanced as that amazing machine.
I used to put 35-40hrs of physical labor into our hand ported GM LT1's. About 4x the labor of "competing" hand ported LT heads. Once we realized we were competing against mediocre to average at best work, it was obviously time to just start cutting the heads instead of spending hours toiling away with a grinder. The quality was always superior, but even our old hand work isn't nearly as good as what we put out now.
Usually 3-5hr depending on the head/program for most LT/LS work. Some heads have 12-18hr in each head, and some are cut in less - it varies significantly. That is per head. Most CNC'd heads are cut on low-end Haas, Fadal, Centroid, etc. type setups, and then they're gone through quicker than we run them. Unfortunately, between pushing the tooling to the limit, and having low-average range machinery it usually shows in the work. High end machinery, custom tooling, and being willing to let it run extra hours for roughing passes etc. ensures our street work is nicer than most of the work high end race teams produce. It also enables us to offer anything from budget CNC work to the nicest work possible w/ today's technology for private label, engine builders, other head porters, etc.
IIRC, the GM LT programs are between 900,000 and 1,050,000 lines of code.
Glad you guys like it. Feel free to ask questions - there is so much misinformation online about CNC head porting that I certainly don't mind dispelling the cylinder head microwave myths.
-Phil
Again, for most people ported stockers are plenty, but don't expect them to go toe-to-toe with aftermarket castings in all situations.
https://ls1tech.com/forums/dynamomet...-gm-5-3-a.html
Didn't read the thread (since I admittedly couldn't give 2 ***** about LSx results), but off the top of my head I'm guessing its comparing a ported CNC'd casting against an as-cast aftermarket head...since we're talking potential, port the aftermarket head as well and then see the comparison.
His post was in reference to the question about aftermarket vs. stock ported and that thread is a perfect answer to that question regardless of LT v. LS.
And those PI heads are CNC ported...just not very well. It is as Apples to Apples as you can get.
"LXR-P1 Performance Induction CNC Ported 215 Heads: $2895
New A-356 Alloy Castings with 11* Valve Angle
Fully CNC Ports and Combustion Chambers
2.040” Stainless Intake Valves
1.570” Stainless Exhaust Valves (3.900 bore)
1.600” Stainless Exhaust Valves (4.000 bore)
Includes Custom Rocker Arm Stands
Uses LS3/L92 OEM or Aftermarket Shaft Rocker Arms
3.900 Bore 62cc or 68cc Chamber
4.000 Bore 66cc or 70cc Chamber
Many Valvetrain and Spring Options Available"
Please tell me how LS results have anything whatsoever to do with that?
The only thing is does point to is AIs quality. If their cnc'ed stockers are as good, if not better, then other companys after market heads, that says a lot. As time goes on it seems like I might end up being an AI nut swinger
The LT1 casting has inherent flaws in its geometry that no amount of porting - short of severe welding/epoxy work - can correct. To compare what a factory LS casting can do vs an aftermarket one means nothing in a conversation about LT1 castings.
What I was getting at, is that it cannot be understated just how wide the spectrum of quality & consistency insofar as head work is concerned actually is. That is especially the case when dealing with the public, since so many purchasers have no way to gauge what they've been given. We have a steady parade of mangled heads brought through. This must be what being a vet is like - having to explain so often that euthanizing is often a better option than surgery.
I would definitely be interested in a video showing how the valvejob is done.
