Running Hotter on the Highway Than In Town
I noticed yesterday that my car runs hotter on the highway than it does in town. What could cause this? I have a stock thermostat in it right now, but the fans are set up for a 160* thermostat if that makes any difference.
Here is where it runs at in town:
![](http://i232.photobucket.com/albums/ee118/Chad_Boone/LT1s/215.jpg)
and this is what it runs at on the highway:
![](http://i232.photobucket.com/albums/ee118/Chad_Boone/LT1s/220.jpg)
I would have thought that it should run cooler when going faster.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
My first guess too. I'm assuming you're driving on the highway for awhile and it's still running hotter? Mine will slowly come down when on the highway. Get under there or unbolt your rad support and make sure you don't have a trash bag or other trash/road debris up there in the fans or radiator.
LS1TECH & Trucks Sponsor
If your fans are set up for a 160* thermostat there's a good chance they are not turning off on the highway like they are supposed to.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
my car does this.......i run 210-215 on the highway but 190 in town..........for me my stock radiator just doesn't have the capacity to cool down the water as fast as a high compression motor can heat it sitting at 3000rpm down the higway.......regardless of airflow........if i was to run a more efficent radiator this would go away........in your case im guessing there is an airflow restriciton.......check for debris in the radiator fins......grass/plastic bags/leaves/animals and small children....
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
Anyways, I have another question: I don't remember how hot the car would run when I first got it, but it seems like it was cooler than that... Is that about where the car should run temp wise with the stock thermostat?
my car does this.......i run 210-215 on the highway but 190 in town..........for me my stock radiator just doesn't have the capacity to cool down the water as fast as a high compression motor can heat it sitting at 3000rpm down the higway.......regardless of airflow........![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Al 95 Z28
Mine runs 210 in town with 90+ degree heat with new waterpump. used be like 230 or so in town. And it gets down to 180 on highway before and with new water pump.
