Torque arm ??
Old Aug 9, 2011 | 07:32 PM
97REaper's Avatar
Default Torque arm ??
I was installing my new clutch and when i went to put the torque arm on i notice the bracket that bolts to the rear was cracked.. its a adjustable Edelbrock t/a.. is there a place that sells a replacement bracket of some sort? I hope i don't have to replace the whole thing... suggestion needed thanks again...
Old Aug 9, 2011 | 07:35 PM
RamAir95TA's Avatar
Doubtful, but you can try Edelbrock.
Unfortunately Edelbrock isn't the best when it comes to suspension. If you can't get a replacement I suggest going with UMI stuff.
Old Aug 9, 2011 | 07:45 PM
97REaper's Avatar
wonder if this would work http://www.umiperformance.com/catalo...roducts_id=470
Old Aug 9, 2011 | 07:48 PM
RamAir95TA's Avatar
Very doubtful...it's made to replace UMI mounts.
Old Aug 9, 2011 | 07:52 PM
97REaper's Avatar
ok thanks..guess ill be looking for a new T/A ..
Old Aug 9, 2011 | 08:07 PM
defaultexistence's Avatar
Get it welded... Duh?
Old Aug 9, 2011 | 08:40 PM
meine96ws6's Avatar
i agree with the above..
Old Aug 9, 2011 | 08:42 PM
Sc0tt30's Avatar
UMI makes some great suspension products. All the aftermarket suspension i have is UMI. I would look at UMI.
97REaper's Avatar
ya im a try and get it welded hopefully it holds up..thanks
Old Aug 10, 2011 | 07:26 AM
UMI Performance's Avatar
We have seen those crack on occasion, that arm is decent but isn't made to handle much power. I don't think our bracket will work either.
I hope that helps,
Ryan
Old Aug 10, 2011 | 11:18 AM
boostedlt1's Avatar
I've seen the edelbrock ones crack there before. go get it welded
Old Aug 10, 2011 | 06:35 PM
97REaper's Avatar
If it doesnt hold up ill be buying a umi T/A.. thanks guys
