V6 to V8 swap
Old Aug 11, 2011 | 08:56 PM
shix's Avatar
Default V6 to V8 swap
Just finished up swapping my 94 lt1 into a 96 v6 car. When i try to start the car all i get is a little click under the passenger side of the dash. I checked voltages everywhere and it all looks good. I can ground the starter out and it will crank. Any help?
Old Aug 11, 2011 | 09:27 PM
snkebait94's Avatar
That happened to me and two wires were touching on the starter. Plus when I swapped to a 6 speed I forgot about the park/neutral safety switch that the autos have. Idk if that helps. It's got to be the wiring on the starter.
Old Aug 11, 2011 | 09:30 PM
shix's Avatar
ill take a look. i appreciate the response. any ideas are welcome.
Old Aug 11, 2011 | 10:04 PM
v7guy's Avatar
there's a starter relay under the passenger side kick panel that sometimes gets cranky/fails, I've also seen the plug that goes into the relay get loose and cause a similar issue. When you turn the ign to start power goes from the ign switch, to the relay, and then to the starter solenoid on the starter if I remember correctly.
Old Aug 12, 2011 | 01:23 PM
shix's Avatar
i got it figured out. wires were touching on the starter. Next problem is the fuel pump does nothing. Is there a relay for the fuel pump anywhere?
Old Aug 12, 2011 | 01:30 PM
Mr_Bond's Avatar
The relay is under the drivers side kick panel on near the floor.
Old Aug 12, 2011 | 02:28 PM
shix's Avatar
going through double checking my wiring i came across this little guy. Anyone know where it goes?
Old Aug 12, 2011 | 03:16 PM
shix's Avatar
nevermind about the prime connector. now to check the relay.
 Michael S. Palmer
Old Aug 12, 2011 | 03:42 PM
shix's Avatar
At the fuel pump relay connector i have voltage only on the red wire. I believe i should have voltage at the dark green/white wire with the key in the run position. Where can i get a wiring diagram for this?
Old Aug 12, 2011 | 08:49 PM
shix's Avatar
So heres what i did to the harness to make it match up to the 96 but i am unsure if the v6 car's wiring is the same. I repinned c210, c100, c220 and added c100 into my existing 94 engine harness so things would match the 96 body harness. The problem is fuel pump relay won't kick on when i try to start the car.
Old Aug 13, 2011 | 01:05 AM
the_merv's Avatar
Veteran: Air Force
There is a wire that comes from the PCM that needs to go to the Interior Connectors and it goes to that Relay.
Old Aug 13, 2011 | 04:34 AM
shix's Avatar
dark green and white wire on the white connector under dash on passenger side behind kick panel correct?
Old Aug 13, 2011 | 01:16 PM
the_merv's Avatar
Veteran: Air Force
Yup. On the LS Harness it'll be in the C-100 Connectors on the wheel well.
Old Aug 13, 2011 | 02:13 PM
shix's Avatar
All my connectors are correct. Still nothing out of the fuel pump. This is frustrating
Old Aug 13, 2011 | 02:41 PM
trilkb's Avatar
not to sound over simplistic, but is the IGN fuse in all the way?
Old Aug 13, 2011 | 02:54 PM
96TransAmboosted's Avatar
So you fuel pump wiring is getting no power?
Did you jupm the harness to make sure the pump works?
Old Aug 13, 2011 | 02:55 PM
shix's Avatar
yeah i can jump it and it works. all fuses are in all the way. everything is connected. I am stumped right now
Old Aug 13, 2011 | 08:15 PM
shix's Avatar
I wonder if i am missing a ground anywhere? Does anyone have any idea where i can get a wiring diagram for the engine bay and engine wiring harnesses?
Old Aug 14, 2011 | 03:40 AM
v7guy's Avatar
shoebox has the wiring diagram posted up.
There are also a couple grounds under the passenger and drivers kick panels
Old Aug 14, 2011 | 05:37 PM
shix's Avatar
verified all of my wiring and checked my connections. Tested the fuel pump relay. Checked my wiring again and still nothing.
