V6 to V8 swap
Old Aug 20, 2011 | 08:30 PM
  #41
shix's Avatar
so if i got a new BCM i could use my key from the 94 and it would work then right?
Old Aug 21, 2011 | 12:39 PM
  #42
the_merv's Avatar
Veteran: Air Force
Just reset it to the key..
Old Aug 21, 2011 | 12:45 PM
  #43
shix's Avatar
I thought it could be programmed only once.
Old Sep 2, 2011 | 04:41 PM
  #44
shix's Avatar
I had VATS tuned out of the PCM. The fuel pump still won't turn on when the key is turned. I am at a total loss now.
Old Sep 2, 2011 | 11:02 PM
  #45
shix's Avatar
Are there any variations in wiring from v6 to v8 cars?
Old Sep 3, 2011 | 12:08 AM
  #46
NewOrleansLT1's Avatar
There is a big purple wire that runs to the pcm. That's the ignition wire. Scrape off some of the insulation and jump that wire to the battery. The car should crank...
Old Sep 3, 2011 | 12:19 AM
  #47
shix's Avatar
it cranks but the fuel pump doesn't kick on
