Clunk coming to full stop?
Old Aug 18, 2011 | 02:07 AM
Sof86's Avatar
Default Clunk coming to full stop?
I've noticed when coming to a full stop the drive line will clunk it feels/sounds like its coming from the back of the car. Anyone know whats going on? Mounts?
Car is an auto.
Old Aug 18, 2011 | 07:09 AM
RamAir95TA's Avatar
The most likely culprit is the transmission mount.
Old Aug 18, 2011 | 07:20 AM
LUNATIK LT1's Avatar
need a little more info... is this felt towards the rear? center of driveline? -
may be a rear u-joint starting to go?
Old Aug 18, 2011 | 10:22 PM
Sof86's Avatar
Feels like its coming from the back, back middle. As the car comes to a full stop and goes into 1st gear you can feel it. Its as if something is loose.
Thanks guys.
Old Aug 18, 2011 | 11:02 PM
rich5368's Avatar
Sounds like a tranny mount to me
Old Aug 24, 2011 | 12:26 AM
gooseit1983's Avatar
Trans mount f bodies at known got trans mount failures it is a cheap fix
Old Aug 24, 2011 | 12:40 AM
my1994z28's Avatar
Trans mount,Torque arm mount or U joint is my guess.
Old Aug 24, 2011 | 10:03 AM
user 4556884458's Avatar
Sounds like transmission mount to me, but there's only one way to really find out...
Old Aug 24, 2011 | 10:17 AM
defaultexistence's Avatar
Put a jack under the trans and lift it gently and see if the mount is separating.. If it is unbolt it and install a new one
Old Aug 24, 2011 | 11:43 AM
96TransAmboosted's Avatar
Get a energy mount much stronger. You will thank me when the stock unit breaks again.
Old Aug 24, 2011 | 06:01 PM
joelster's Avatar
x10 on trans mount. It takes 20 minutes to replace. It will break again sometime though, unless you move the torque arm off of the tail of the transmission with a different crossmember.
Old Aug 26, 2011 | 05:28 PM
Sof86's Avatar
Thank you all for the confirming what the problem is. I'll have to get it checked out and order an energy mount, thanks 96TransAmboosted. Is it still OK to drive it like that until I have it fixed?
Old Aug 26, 2011 | 07:12 PM
FAD2BLK93's Avatar
When my mount broke i felt it on the take off directly under the tunnel scapin the bottom of the car. I would say rear ujoint or backlash on the ring and pinion possible, is it clunking going from drive to reverse with ur foot on the brake?
Old Aug 26, 2011 | 09:23 PM
OnA Fan's Avatar
Check trans mount first. When mine tore apart, I thought I my rear end was about to fall out.
Old Sep 12, 2011 | 09:42 PM
Sof86's Avatar
I finally had some time to take the car out last night. The clunk def feels like its coming from the center of the car, by the tranny tunnel. There is a slight clunk going from P to R.
Now another problem came up, when I started it, it kinda stumbled and didn't wanna start. So I primed it again, checked fuel pressure, all is OK, turn it on, it starts. I start driving down the street the ABS light comes on. Then I'm waiting at the lights, all my lights turn off and the car stumbles and starts again now my handbrake light is on and airbag (I think it was). The car did the same thing 3 other times coming home. What a nightmare. Dunno where to start.
Old Sep 13, 2011 | 04:53 AM
camar0corey's Avatar
I usually think of a loose ground somewhere when the dash lights go all funky.
Old Sep 14, 2011 | 12:21 PM
ahritchie's Avatar
Not sure if this helps or not, but I've had my 94 Formula since 1997 and every once in a while (once every few months) the ABS light, service engine light, airbag, low traction (my car does NOT have traction control) will come on for no reason whatsoever when driving. Shutting it off and restarting brings everything back to normal. Seems to be some electrical/computer/ABS gremlin that only occasionally pop up. No big deal though.
Old Sep 14, 2011 | 02:06 PM
djjab57's Avatar
If its the Trans mount you will feel the "Clunk" right there pretty much under you
Old Sep 14, 2011 | 10:44 PM
Formula413's Avatar
+1, the problem in the original post does not sound like a trans mount to me. I actually have a similar noise and it is not the trans mount, I have broken two of those so I'm very familiar with that. A broken trans mount will result in a bang almost right underneath you when you take off hard.
