Source for Water Pump Seal tool?
The Arkansas state trooper pulls over a pickup truck on I-40. He says to the driver, "Got any ID?"
The driver says, "Bout what?"
It's one of those seals that needs a little more attention. Round seals are always an issue, because you must install them straight and flush. If you tweak it a little during install, it may distort it and cause it to leak (good reason to use a seal driver). The w/p seal is more problematic due to the inner lip getting caught on the drive shaft. Everyone seems to complain about oil leakage on LT1s, but mine has been just the opposite. The only spot is a tiny bit of seepage from the front of the oil pan. My garage floor rarely has a drop on it.
What car do you have?
While we all do appreciate your input and suggestion of your cool looking seal tool, it is kinda against the "for sale" rules around here. No worries tho, it's a common newbie mistake that most everybody's made at some point.
If your tool is good, others will start blabbing about it here.
Boy that sounds like a whole different topic
A little reasonable care and attention and you're good.
