Got a bone to pic!!!!
Old Aug 29, 2011 | 07:31 PM
jrplz's Avatar
Angry Got a bone to pic!!!!
I have a 1996 camaro does anyone have the same problems with knn air intake (with the filter coming off) Ive gone through 2 filters all ready the come loose and bang around and get damage. Is it just me or does any one have this problem?
thanks
Jr
Old Aug 29, 2011 | 08:05 PM
jflores.281's Avatar
Never herd of that problem... but try a different clamp?
Old Aug 29, 2011 | 08:10 PM
R3DLT1's Avatar
just u
Old Aug 29, 2011 | 08:13 PM
THENASCAR's Avatar
sounds like possibly a mixture of oil and a shitty clamp.
Old Aug 29, 2011 | 08:17 PM
Badazz 97 TA's Avatar
never had that problem.
Old Aug 29, 2011 | 08:18 PM
jrplz's Avatar
http://camaroforums.com/forum/intake...pid-k-n-39636/
http://www.camaroz28.com/forums/showthread.php?t=309144
Old Aug 29, 2011 | 08:20 PM
00FlowCamaro's Avatar
Put the clamp on tight enough?
Old Aug 29, 2011 | 08:31 PM
jrplz's Avatar
yes ! trust me but the plastic not having a lip for the clamp represents the problem IMO the other kits have a lip o well
Old Aug 29, 2011 | 08:53 PM
defaultexistence's Avatar
If your getting to much motor movement I could see the cai parts working loose.. Maybe your motor mounts are worn out, then again maybe it's the opti ..
Old Aug 29, 2011 | 09:04 PM
Wicked94z28's Avatar
I kinda had that problem, have someone stand at the top and hold down while you push up on the filter to make sure it goes over the lip then tighten the **** outa the clamp..
Old Aug 29, 2011 | 09:23 PM
MICHZ28's Avatar
I had the same problem, a few mods to it and problem solved.
Old Aug 29, 2011 | 10:18 PM
airfix's Avatar
I had the same problem a while ago, the intake tube actually colapsed some how which made the diameter smaller and the filter fell off. I got the heat gun out and reshaped the colapsed part of the intake tube. After that I had no issues, just make sure you get the filter up on the pipe as far as you can.
Old Aug 30, 2011 | 07:18 AM
uzeial's Avatar
This has happened to me. Fell clean off after an unexpected pothole on a rainy day. I was amazed I didnt suck in any water.
Old Aug 30, 2011 | 07:34 AM
LT1FirebirdSLP's Avatar
Are you getting any backfiring? The combination of no lip and a solid backfire could sure knock your filter off.
Old Aug 30, 2011 | 07:38 AM
SS RRR's Avatar
Village Troll
I am wondering if you're tightening the clamp too much and causing the tube to buckle.
Old Aug 30, 2011 | 08:09 AM
ZGOBYBY's Avatar
This isn't uncommon actually, I have heard of a few people having their filter fall off. I had the same kit at one time, and I was concerned about it myself, but it luckily didn't fall off.
Old Aug 30, 2011 | 09:46 AM
uzeial's Avatar
I doubt it. I got sick of dealing with it so I got rid. The whole thing. Right now it has the stock filter. I want to move to a ram air hood anyways, may as well wait and make it functional...
96TransAmboosted's Avatar
I bet the mounts are letting the filter move and the filter is getting caught on the hole and pulling off. If that's not it then it must not be installed correct.
Old Aug 30, 2011 | 10:02 AM
FAD2BLK93's Avatar
Just u...tighten the clamp with more than a screw driver, and put a self taping screw in it.
Old Aug 30, 2011 | 10:48 AM
RamAir95TA's Avatar
I don't have this problem with my WS6 airbox...
