Porting heads
Old Sep 1, 2011 | 12:27 PM
FAD2BLK93's Avatar
Default Porting heads
Hey guys heres a question...i have a spare motor from a 97 ws6 the motor has 52,000 on it. So i pulled the heads off and i want to do some home porting, gasket match the whole bit. I want to swap with my 93 heads until i get enough money to send them to do a LE2 setup. I have been told they can port '93' heads more than the rest, is this true? And how much extra power can i get porting and is it worth the work? One more i want to change the head gaskets from .050 to .028 i think it will give me 11 to 1 ratio is this to much for 182k? Thanks
Old Sep 1, 2011 | 01:36 PM
Camaro350Z28's Avatar
182k? why dont you use the 52k block?
Old Sep 1, 2011 | 03:42 PM
RamAir95TA's Avatar
More often than not home porting heads gets you nowhere or you end up with a ruined set of heads. There's far more to it than just gasket-matching and going nuts with a Dremel. It's not for the beginner, nor are the gains on a stock cam worth the risk. You're talking MAYBE a handful of HP, if that, even if done properly. Chances of that happening on your first go-around with home-porting are nil.
Leave the heads alone.
Old Sep 1, 2011 | 03:47 PM
BLK95-Z's Avatar
I think the best for porting were the 643's, they came on the 94-95's. Performance wise in stock trim is pretty much even.
Old Sep 1, 2011 | 03:49 PM
Dave357LT1's Avatar
Or find a set of junk yard heads that you can learn on!!! You cant be a beginner if you never try. Get some books, videos and take it slow.
Old Sep 1, 2011 | 06:30 PM
FAD2BLK93's Avatar
I do have books and videos and this is not truly my first go round, i was hoping to get 20-25 hp out of them. The 182k motor still pulls 13.5 @105 so it is still going strong. Just thought i would gain a little. Anybody know about the headgasket thickness is that correct at 11 to 1?
Old Sep 2, 2011 | 09:15 AM
Mystery Bird's Avatar
It can be done. But like Ramair said it's not for everyone and most screw it up. I spent about 30 hours researching before I ever even touched my heads, but it paid off and saved myself about $1000.
Old Sep 2, 2011 | 09:28 AM
FAD2BLK93's Avatar
Anybody have any tips, on porting? Short side radius...bowl work ect. Anything would be helpful, i plan on basiclly doing a gasket match and smoothing the runners out. Thanks
Old Sep 2, 2011 | 09:38 AM
draggin97s10's Avatar
your main focus should be in the bowl if you are lightly porting them, this is where you will see the most gains.
Old Sep 2, 2011 | 10:10 AM
defaultexistence's Avatar
https://ls1tech.com/forums/lt1-lt4-m...ters-come.html
eBay for the carbide bits..
Old Sep 2, 2011 | 10:21 AM
RamAir95TA's Avatar
Popular mistake - don't polish the intake runners.
Old Sep 2, 2011 | 10:37 AM
yep, actually hurts atomization.
Old Sep 2, 2011 | 10:44 AM
jankie93z's Avatar
I might be wrong but mr gasket 5717 will bump the cr a bit
Old Sep 2, 2011 | 10:58 AM
Be careful gasket matching you can really screw up the heads that way.
Old Sep 2, 2011 | 11:22 AM
whytryz28's Avatar
http://www.popularhotrodding.com/tec...g/viewall.html
http://www.popularhotrodding.com/eng...s/viewall.html
Read, read, read. David Vizard knows his ****.
Old Sep 2, 2011 | 11:25 AM
96TransAmboosted's Avatar
Don't ever let the bit stop while touching the head or start the bit while on the head. Also be very very careful when in the valve margen area. I also suggest haveing a valve job done afterwards your more likely than not to hit that area your first few times. If you get bits get a few diffrent lengths to make thing a little more easy to control the bit. Good luck
Old Sep 2, 2011 | 12:00 PM
I put duct tape around the seats and the stem of the bits when working in the bowl area to protect them.
Old Sep 2, 2011 | 01:06 PM
mguidry629's Avatar
If I would have taken all the hours I spent porting my heads and put in overtime at work, I could have bought 2 sets of LE2's or one set of CNC'd heads. And would have way better results. I had mine flowed, but I haven't put the motor in yet, so we'll see what the dyno and track times say about the port job. One day....maybe....hopefully.
I don't regret doing the home port job....yet anyway. I had fun and it was good experience. Just plan on spending 40+ hours if you're trying to get to >195cc and have them all match, etc, etc.
I've been having an experimental set of 561 castings that have been in my garage for a few weeks and I just can't bring myself to start all over again. I don't know how some guys do it on a daily basis and stay motivated.
Old Sep 2, 2011 | 02:11 PM
When you have templates to follow I would assume you can do it much faster. I know the next set I do for my Firehawk clone will go a lot faster.
Old Sep 2, 2011 | 03:48 PM
FAD2BLK93's Avatar
Thanks for the input guys!
By Brett Foote | 2026-06-04 05:00:17
