Starting help
Old Sep 11, 2011 | 09:23 PM
Luke1996ta's Avatar
Default Starting help
Well I just got my computer back and installed after my cam swap and heads now it won't start!!!!!! opti? It acts like it wants to fire every once in a while but other times it just seems to turn over and not get spark where should I start the opti worked before this so was wondering what it would be
Old Sep 12, 2011 | 04:54 AM
Luke1996ta's Avatar
No one
Old Sep 12, 2011 | 06:18 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Did it run before you pulled the PCM?
Check the multi-pin plugs, fuses, etc.
Old Sep 12, 2011 | 06:23 AM
RamAir95TA's Avatar
Like Paul mentioned, it is unlikely that a working part stopped working after removal and reinstallation. Definitely check fuses, plugs, coil wire, grounds, etc. It is likely something you did.
Old Sep 12, 2011 | 06:49 AM
Luke1996ta's Avatar
Ya everything worked before removing it and I just put new plugs and wires on with the cam swap
Old Sep 12, 2011 | 06:59 AM
lt1slowz28's Avatar
check to make sure you put the opti on correctly. In my case I had installed it, everything looked fine but had only a sputter every now and then and it was overly rich.
Checked spark, strong, fuel proper, everything in order, ended up ordering an opti and upon installation of the new one I found that my old one was just fine, only was off by one hole. (yes the dowell will go into the non keyed holes fine... PITA)
Old Sep 12, 2011 | 07:22 AM
Luke1996ta's Avatar
Sounds just like mine it wants to start every once in a while
Old Sep 12, 2011 | 07:36 AM
Luke1996ta's Avatar
Can u take the opti off with the balancer on or do u have to take it off and on the opti how do u know what hole to put it in?
Old Sep 12, 2011 | 08:26 AM
RamAir95TA's Avatar
The OEM balancer needs to be removed. It's just three bolts so no big deal.
It should be VERY obvious which hole the opti pin needs to go in. If you weren't sure of this before then there's a 2 in 3 chance you indexed it incorrectly and pulled the opti on into the wrong hole.
Old Sep 12, 2011 | 01:39 PM
Paul Bell's Avatar
To be a little clearer, the balancer on the LT1 engine has three bolts that hold it to the balancer hub. GM designed it this way to get it out of the way of the Opti without needing to pull the entire thing off the crank.
I'm also starting to think the Opti is the culprit.
Old Sep 12, 2011 | 02:16 PM
Luke1996ta's Avatar
So your think I have to dowel pin in the wrong hole
Old Sep 12, 2011 | 02:46 PM
RamAir95TA's Avatar
It is not a certainty but a possibility.
Old Sep 12, 2011 | 03:17 PM
defaultexistence's Avatar
IMO ,anytime you work with the opti, it's a good idea to try and start the engine before putting the pump and everything else back in the way.. Firing up for a few seconds without the pump on or water in the block won't hurt anything and will save you a possible headache if it doesn't start . Just install the balancer once you check and reindex the opti and see if it starts before reinstalling the pump an filling with coolant this time.
Old Sep 12, 2011 | 08:05 PM
Luke1996ta's Avatar
I got it to start thanks guys
Old Sep 12, 2011 | 09:57 PM
Paul Bell's Avatar
GREAT!
I was about to give you a laundry list of things to check.
So, what fixed it?
Old Sep 13, 2011 | 04:25 AM
RamAir95TA's Avatar
I hate when people do that.
POST UP what the problem was so maybe other people could learn something.
Old Sep 13, 2011 | 04:57 AM
Luke1996ta's Avatar
I had the opti in the wrong hole put it all back together and she started right up
Old Sep 13, 2011 | 09:58 AM
lt1slowz28's Avatar
Had me stumped as well, cost me whatever a new opti was when i did it. Glad you got it figured out.
Old Sep 13, 2011 | 10:43 AM
SS RRR's Avatar
Village Troll
It should be very easy with a dowel opti to know you have it on right. To have it in the wrong hole would mean you would really have to put pressure on the opti for it to sit flush and that's if it would. When it is in the correct hole it will go on with no resistance whatsoever. Lesson learned I reckon.
