Use stock rods for 355?
I want to keep the stock crank. Im not sure on pistons and rods yet. I figured forged pistons would be a must but Im not sure if I should re-use the stock rods or if I should go with a forged set.
Goals for the car will be mid 11s and around 420RWHP.
What do you guys recommend?
Topend will be one of the big two names on here, I havent decided yet, and dont want to get into that.
...with that said polish the stock crank and get the rods resized for ARP bolts and good forged pistons.
spec a cam you dont need to spin past 6200 that makes good power
for nuts out cam specs then just go forged all the way
Stock pistons won't leave you any margin for tuning error on a 150 shot, although I know people doing it.
The stock crank is the least of your worries.
The stock 2-bolt mains are fine for 6500 rpm and a 150 shot.
From everything Ive read stock rods are pretty strong and can handle some decent power with ARP bolts. Just make sure your tune is good.
