cam package help for 96 impala
Anyways, no one can really help you until we know what kind of build you are after on the car. Is a a daily driver? A show car? A drag car? A weekend warrior? If you just want to get h/c package for a daily driven car, lpe makes some good stuff. Then of course you have the LT4 Hotcam which is always good for daily driven lt1s. Give us some more info on what you want to do with it. If its just a dd car and your looking for more streetable power, I would just get a stall (assuming its automatic) and a lower rear end gear. Then some bolt ons would really wake her up. I'm not really sure if I would go for a 373 or a 411 rear gear in a car that heavy. Maybe a 342. I dont know a whole shitload about impalas. But bolt ons and gears are always a good idea.
http://www.impalassforum.com/vBullet...d.php?t=228114
and then come back and tell us what you want to do with the car.
I had mine going 12.3's with the stock cam, so don't think by any means that a cam is necessary to make it a fairly quick car.
Mine is complete with AC, power seats, ABS etc yet.
If you follow advise from guys like Pat and I you can have a daily driver Impala that will run 12s on your normal street tires.
Back when I had a slightly milder heads/cam package from the same company I ran 12.6 on the street tires right after a 150mile drive to the track, with the tools and slicks in the trunk yet. You can do the same.
The 3400stall might be slightly more than you want but the 3.73s I had in the car then are likely perfect for you. I had 3.42s when I put 20K on a year those should have been stock instead of the 3.08s.
You do NOT want MSD plugs or any fancy plug at all those of us going fast tend to use plugs that are under $2 apiece, the MSD opti is JUNK much LESS reliable than stock.
K&N intake is OK IF and only IF you need to pass emissions inspection, if inspection is not a concern you can accomplish the same thing for probably a third the price or less.
Far as a performance "chip" these don't have chips and any of the piggyback chips that companies sell to modify pcm commands are junk. Custom pcm reprogramming can be good and is required with some modifications. It also cost far less than something like Hypertech which has been shown to pretty reliably SLOW cars down.
I know I am telling you your existing ideas are poor and the input you are getting elsewhere is even worse. Please don't be offended, take this opportunity to learn from Pat and I as we have been at it a good long while and we can save you a lot of mistakes and wasted money IF you let us.
Most 383 b-bodies are not even as fast as my car much less as fast as Pat's.
There is also a LOT you need to do to a car before it is time to really do much to the engine, you need cold air intake, exhaust from headers to tips, a little suspension work like aftermarket rear lower arms, a good performance tranny rebuild(or at least shiftkit) from someone with a proven trackrecord with the 4L60E, rearend gears which might require a new driveshaft. Once you get into the engine you need things like bigger injectors and fuel pump, larger throttle body.
It adds up to a lot of money fast, in the end though you have a big, fast,comfortable car that you can enjoy driving or take to the track and spank a nitrous LS car done the magazine article and Summit way.
LOL it means there are tons of companies that would love to separate you from your money for little to no performance gains and sell you shoddy products. Do your research...cold air intake, headers, dyno tune, stall, gears, roller rockers, then you can START thinking about stroking, cam, heads, ect. ect. To put that in perspective a stock Impala has about 220rwhp, with nothing more than rocker arms and valvesprings swapped you can put that number up into the 300rwhp range, headers, CAI, full exhaust, tuneup, custom reprogramming etc.
Then heads and cam can push it up to the 400rwhp-425ish range like Pat's has domumented, then the 383s using the same heads and slightly larger cam have been shown to make440-455rwhp.
If Pat had a lockup converter in his car I think he could easily show another 10hp or so at the wheels which is getting really really close to doubling stock rwhp without a stroker build.
You have a LOT to do first but just so you can see more of why I keep refering to Pat's car when mine is similar, his is better documented.
https://ls1tech.com/forums/lt1-lt4-m...1-119-7-a.html
Mine is slower because it is not as refined as Pat's and is more of a street car heavier, less stall etc. Pat has always been wonderful at wringing everything out of a car so his results are harder to duplicate without his skill. I on the otherhand just bolt good parts together competently which should be easy to duplicate.
It is just fine to put a cam in these.
We cammed a friend's Caprice(former cop car) at 160K miles a year and a half ago just shy of 200K we pulled it out and put it in his WIFE'S car another daily driver Caprice. I haven't asked what the current mileage is but I know where they live and where she works and it has to have at least 215k miles on it.
When it was still in his car we went to a big national Impala gathering, my car was FASTER than most of the 383 and larger engine cars and his cam only car was within a couple tenths of them.
You said it only has 50K on it? That is barely broken in.
If I were to dyno it now with the non-lockup ATI 4200, I'd guess it would show a "loss" of probably more than 10 hp.
Jim
