Hotcam goes 10's...
When it comes time to build the shortblock, I'll be sure to touch base with you for some advice.Thanks. I wanted to be a little unique.
...or, it was just a turd
When it comes time to build the shortblock, I'll be sure to touch base with you for some advice.I just made a few recent changes and am hoping to get a couple more tenths out of it.
Im also running the nitrous outlet plate kit. Ive hit it with 100 shot and spun bad with a 1.58 60' coasting through the traps (had to shut it down early due to a upper rpm miss) it went 7.00@100 in the 1/8th. Im sure it will go 6.60's when the 60' gets down in the 1.4's and I get a clean pass.
Congrats again!
Austin
Congrats!!!
Lol bring back the dead
Back n 97
I had a bolt on TA...3900lbs....M6.... No tune...
Stock 16s with DR
With a moser 9in 4.10
12.68@108 1.68 60ft dead hook on the limiter
100shot
11.7 @ 120
Congrats again!
Austin
And regarding the 396 setup from 10 years ago, the MPH was there, so most likely with an A4, while still maybe not outstanding numbers for a 396, it was still a 10-second car. I think some things have gotten better over the years (tuning, Nitrous Outlet plate), but mostly I think more experience produces better results and drives the expectations up. And let's face it, a 10-second car just isn't as impressive as it used to be thanks to our LS brethren.
Thanks.
