355 or 383
Old Oct 10, 2011 | 10:55 PM
ale76051's Avatar
Default 355 or 383
I'm about to start the engine building process but i am stuck between a 355 or 383. I hardly ever take the car to the strip but like to air it out every once and a while on the highway. I'm planning to run a 100-150 shot with Le2 heads. Does anyone have a suggestion as to which way I should go? Thanks
Old Oct 10, 2011 | 11:17 PM
BigBadWhitey's Avatar
Are you buying a whole new rotating assembly? Then id go 383 while its apart.
I wouldnt bother buying a forged setup and staying stock cubes, but thats just me.
Old Oct 10, 2011 | 11:45 PM
Rob94hawk's Avatar
The reality is it depends on how deep your wallet is. With a 383 you're talking all new internals. Preferably starting with a forged crank, pistons and billet splayed mains especially if you're running nitrous.
My rebuilt 350 short block cost me $1500.
Old Oct 10, 2011 | 11:53 PM
96SilverZ's Avatar
since you probably aren't going to want to rev it to space i would recommend 355 with forged pistons and/or rods and stock crank. you will probably hit 400whp with those LE2's depending on cam
Old Oct 11, 2011 | 04:02 AM
ale76051's Avatar
Thanks I plan on doing a complete bottom end rebuild since I just rolled 190k
Old Oct 11, 2011 | 04:44 AM
RamAir95TA's Avatar
The only difference between the two is the 383 requires a new crank and clearancing of the pan rails for the increased stroke. You're talking a ~$500-$700 difference between the two. But if you opt to use a non-stock crank in the 355 then the cost between the two is ONLY the cost of clearancing the pan rails. Dollar for dollar a 383 will make more HP/TQ (usually) than a comparable 355.
Short version - Do the 383. I had the same dilemma when I chose to do a build and I'm glad I went with the 383. You'll have second thoughts GUARANTEED when you have it all apart and that stock crank is getting dropped back in when a stroker crank could easily be in its place.
Also consider that a 383 requires a more aggressive heads/cam to utilize that added displacement.
Old Oct 11, 2011 | 10:34 AM
ls2pontiac's Avatar
Self-Admitted Scammer
Hmm..i thought the stock cubes were best if you plan on revving the absolute crap out of the motor all the time since it was less stress than a stroker? Or if you are going to be boosting it. Well thats the reason i didn't want to stroke mine.
Old Oct 11, 2011 | 11:42 AM
96SilverZ's Avatar
^True, but I was reffering to forged crank vs. stock cast crank and if you go forged you might as well make it a stroker
Old Oct 11, 2011 | 05:09 PM
FASHOOTER's Avatar
Do the 383 and don't look back! Glad I did
Old Oct 11, 2011 | 05:20 PM
ale76051's Avatar
Thanks
Old Oct 11, 2011 | 06:04 PM
96lt1m6's Avatar
There is nothing wrong with a 350"-360" non stroked small block, with the proper camshaft,head choice along with a bit more compression and the need for more RPM you will have a sweet set up.
If you want to spend a few more $$$$$$$$ as Joe stated you can build a 383-388 stroker, this set up will create a bit more HP and of course the TQ numbers will jump Personally i am a fan of BIG TQ#s at lower RPM #s...... Either way you go it will put a smile on your face and a dent in your wallet....... Just remember if money is tight get your heads done first,just like in real life GOOD HEAD GOES A LONG WAY!
Old Oct 12, 2011 | 09:47 AM
SpeedDensityZ's Avatar
Go 383, if you were to use the same exact H/C/I the car would be a ton more streetable. More cubes equal better drivability. I wish I would have went back 383 when I didi the rebuild but I was on a tight budget at the time. The car was a beast then. It's still quick but with the 383 I was able to run a bigger cam which means more power. Do me a favor, if you decide to go 383 go forged, I broke a cast steel eagle crank at 450rwhp NA.
Old Oct 12, 2011 | 09:50 AM
Camaroking1996's Avatar
How does more cubes equal better drivability?
Old Oct 12, 2011 | 09:51 AM
quik95lt1's Avatar
^exactly what joe said...
the stock lt block is more than capable of handling a high rpm 3.75" stroke.......ive been taking my 385 to 8000+rpm for 4 years now.......
theres no replacement for displacement!!!!
Old Oct 12, 2011 | 10:05 AM
Mississippi's Avatar
396 stroker. That's all. Haha. Depending on the size of your wallet and the limit on your credit cards. Lol.
Old Oct 12, 2011 | 10:48 AM
Rob94hawk's Avatar
The cam wouldn't have to be as radical in a 383 to achieve the same hp levels as a 350.
Old Oct 12, 2011 | 11:01 AM
SS RRR's Avatar
Village Troll
Depending on how good the top end is, more air, more combustion, more rotational force (torque) which equates to more smiles.
Old Oct 12, 2011 | 11:03 AM
I thought power and torque was mainly made by the top end.
Old Oct 12, 2011 | 11:06 AM
SS RRR's Avatar
Village Troll
It absolutely is. That's why I said depending on the top end parts used. There have been those who've stroked an engine and used stock heads/intake and it ran like dog ****. Had great torque for a few thousand rpm, but fell off because the engine was being strangled. You have an engine with a longer stroke it is going to demand more air. If you have the top end parts to complement the longer stroke then good things will happen.
Old Oct 12, 2011 | 12:02 PM
quik95lt1's Avatar
thats a negative there ghost rider lol
