compression and boost question with a cometics head gasket
i can go up to a .60 gasket thickness, so i was wondering if lowering the compression would let me run any more boost? i am running 8lbs now and i have a good valve train and a thicker gasket with studs would i be good to run any more boost? or does it not work like that
thanks
then again im ballsy, but my motor is forged and stroked i have a 10.7 compression and i run 15 lbs on a supercharger all day, but i also have water meth (80% meth) and run 93 octane. no intercooler here, maybe someday.
you crazy
Just STFU and learn. You are talking just to hear yourself.
i was talking with a guy and he was saying how it takes usually takes extreme heat to blow a head gasket and since i never ran hot, he thinks that i blew a hole in the head... or however you say that... cracked it?
i can see this as possible because i was running a how plug when i was gonna switch over to the nkg 6 i was just test driving it.... also do you guys think my piston rings are fine? cause im pretty sure detonation can kill them too...
im still learning about the internals of motors and all that goes with them so no hatin
Tight quench creates more mixture motion, a faster more efficient burn, and therefore less need for ignition advance.
Do you mean stock castings reworked and ported or genui9nely stock castings with aftermarket valves? Ported stock castings can be a GREAT option for most builds. Putting aftermarket valves in an otherwise untouched head is just pissing money into the wind.
