Give me some ideas for fastest cam only options
Good point, if someone shifted at the 5800rpms Comp lists as the top of the range for that cam it would decimate MPH because you would not get near the top of the power curve.
With untouched heads I would expect it to want 62-6300 easily and with good ported heads 6500 for sure.
First passes id launch at 3-3500 rpm and shift at 6k and would net around 14-13.8. Then by launching at 5k rpm and shifting at 5800-5900 i got down to 13.5s. I thought Shifting around 6200-6500 might bend a rod or something on a stock bottom end? Is that false?
what was your 60' on that run?
And you still havent answered what rpm it was shifting at.
If it was a 2.1 or higher then thats your issue. Knock it down to a 1.8 or so and your looking at a high 12 second run. 1 tenth on the 60' means about 2 tenths on the 1/4. So a 13.4 with a 2.1 60' would be a 12.8-ish with a 1.8 60'.
I would expect since its a 6 speed thats lowered, the launch is your problem.
I would ditch the lowering springs for stockers and do the lca relo brackets.
But everyone still needs to know what rpm it was, this effects a cc503 hugely.
Also, like stated, in a lowered car LCAs and relo's help a ton. I wouldn't be surprised if the back of the LCA is higher then the front.
You just need to up the shift point rpms. More times then not a 6300rpm shift isnt going to do damage anything, but of course some people just get unlucky.
#33
Well Id get that taking care of. Sometimes a loud leak can cause false knock. Not the standard but it has happened. Like said before shift at a higher rpm. You can spin a stock short block to 6600rpms. I wouldn't do it everytime I drove the car but under racig conditions I would. I mean how often are you really rev'ing the **** ut of your car? Like I said before between the factory tach being off by on average 300 rpms during wot in th upper rpms and you shifting at 5900 your leaving alot on the table. Go out and try shifting when you feel the car nose over. Where that rpm is try shifting just before that. Thats how I set my rpms on my car. Its way above factory shift points for a stock cam but then again how many bolt on lt1's trap 108 on a 80 degree day with 1400ish DA
#35
Ok heres what ill do in the matter of two weeks and see what happens...
-swap in a 3.73 rear end
-buy some adjustable lcas
-maybe even put my stock springs in the rear for the day
-get the y pipe and catback welded
#36
That means he is short shifting at the most 5700 on a cam that will easily pull to 6200, even on stock heads. He should be shifting above that, at 6300+...preferably 6500 if he thinks his engine is in good condition.
I'm sure his tune also is leaving some potential on the table, but shift each gear almost a full 1,000 rpm early and see how much mph you drop
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#37
yea thats no good lol
holy high rpm lol....
I can see close to 9mph gain if he is shifting a cc503 car at an indicated 5800.
