Valve?
Old Oct 17, 2011 | 03:43 PM
quik95lt1's Avatar
ill solve this whole thing........go to wal mart and buy a thing of play douh mount the head on the shortblock and spin it by hand carefully and game over........
good luck
Old Oct 17, 2011 | 03:50 PM
Luke1996ta's Avatar
O don't for get about jb weld either better pick up some of that to while your at it
Old Oct 17, 2011 | 03:54 PM
joshh123's Avatar
Originally Posted by 96capricemgr
Let's throw out there the likelyhood of needing new seats since LT1 heads need them for a 2.02 valve I have to believe LT4 heads would need new seats for a 2.08 valve. Haven't seen anyone try it but I doubt you will find flaw with the reasoning.
dude.. please stop with the bullshit. these heads have had 2.08's in them for the past 3 years. and have been run. and put out 447rwhp and 441rwtq only revving to 5700rpm. so please.. please stfu about it. the heads were done by LE. i am sure he knows what he is doing. how about we stay on the topic.
Old Oct 17, 2011 | 04:05 PM
96capricemgr's Avatar
Originally Posted by Jerry Clayton
I don't believe you'll get them in the head if they are in stock location----if you do--they will be severely shrouded by the chamber wall and cylinder wall(if they clear)
On heads with bigger valves you will find that the intakes are moved toward the center of the chamber and the exhaust valve is moved even further over to give the intake room in between them
then there is the issue of your piston's notches aren't big enough for 2.080 valve and if they were they probably aren't in the right location
Have any reply to this?
Old Oct 17, 2011 | 04:19 PM
draggin97s10's Avatar
ive heard of it being done before....so put them on and check ptv clearance...then youll know if they work...
Old Oct 17, 2011 | 06:47 PM
andrew ws6's Avatar
Why not just call Llyod and ask him? You have not responded to anyone other than 96capricemgr seems like this thread was to start an arguement.
Old Oct 17, 2011 | 07:25 PM
quik95lt1's Avatar
tell me about it ive gave two threads with good info and it was competely ignored.......
