How to plug heater core lines from waterpump?
Old Oct 20, 2011 | 03:48 PM
bufmatmuslepants's Avatar
Default How to plug heater core lines from waterpump?
Does everyone else just loop them or do you put a plug in the hose or crimp the outlet shut and solder it?
Old Oct 20, 2011 | 06:47 PM
FormulaJoe's Avatar
Freeze plug. Pop that nozzle out the pump and pop the plug in.
Old Oct 20, 2011 | 06:49 PM
Brass freeze plug available at any autoparts store?
Old Oct 20, 2011 | 06:50 PM
RamAir95TA's Avatar
-Loop the lines
-Remove the fittings and have them welded shut
-Remove the fittings and tap them for pipe plugs
-Remove the fittings and plug them with freeze plugs
Those are your three options.
Old Oct 20, 2011 | 06:59 PM
FormulaJoe's Avatar
Here's where the oil cooler line used to come out...
Attached Thumbnails How to plug heater core lines from waterpump?-img_1314.jpg
Old Oct 20, 2011 | 07:04 PM
Formulajoe that's a freeze plug?
Old Oct 20, 2011 | 07:09 PM
FormulaJoe's Avatar
It is, O'reillys didn't have a brass one that size or something.
Old Oct 20, 2011 | 08:21 PM
blown97ss's Avatar
nice so on the lt1 we can plug the water heater lines and the oil cooler line? that would clean my eng bay up alittle
Old Oct 21, 2011 | 12:21 AM
gjohnsonws6's Avatar
I dont have an oil cooler but I used rubber caps and hose clamps.I think you can get them at any auto parts store nothing special really
Old Oct 24, 2011 | 03:17 PM
xrambbc's Avatar
ok so the oil cooler lines and heater lines can be removed without overheating problems? so then to blead the system you just use the one on the thrermo housing? just want to make damn sure before i remove them.
Old Oct 24, 2011 | 05:40 PM
camaro350's Avatar
what size of freeze plug is it?
