Timing Chain ?
Old Oct 27, 2011 | 03:19 PM
djjab57's Avatar
Default Timing Chain ?
Ive done a search but didn't come up with anything useful SO What sets are you guys using, Stock replacement ? What do you think of the Lunati 93094 ? 1 key or 3 key. I started my build a while back but not I am finally going to finish just need a few parts such as the Timing get a new water pump and a few other odds and ends. If it matter its a 355 LE2 heads cam ported intake. Forged Mahle pistons and Forged Scat 6 inch rods stock crank
Thanks for any help guys and girls
Timing chain is for 92-94 1/2 LT1
djjab57's Avatar
And im getting a 3 piece
Old Oct 27, 2011 | 03:21 PM
bowtiedad_z28's Avatar
Might need the year of your car or motor to answer that.
Old Oct 27, 2011 | 06:43 PM
Luke1996ta's Avatar
I used a cloyes set u get the chains and both gears for around 80 to 90 bucks
Old Oct 28, 2011 | 08:51 AM
draggin97s10's Avatar
so did i went on nice and tight....C3909 IIRC
Old Oct 28, 2011 | 08:54 AM
djjab57's Avatar
But did you use a EWP
Old Oct 28, 2011 | 08:55 AM
djjab57's Avatar
I believe on mine if I use a Cloyes I have to use a EWP
Old Oct 28, 2011 | 09:40 AM
c3909 is stock replacement
Old Oct 28, 2011 | 09:42 AM
djjab57's Avatar
Yea I have all the part numbers thanks. Thats were shbox.com comes in handy
Old Oct 28, 2011 | 09:45 AM
djjab57's Avatar
These are the 2 im looking at
3 key http://www.ebay.com/itm/140624277106...84.m1438.l2649
1 key http://www.ebay.com/itm/390358554411...84.m1438.l2649
Old Oct 28, 2011 | 12:25 PM
1963SS's Avatar
I've used several of the Cloyes 3157.. It's a true roller and requires no clearancing of the timing cover. It's a single roller but boy what big rollers they are. I've not noticed any stretch on teardowns 3-4 years later. Might gain a few horses over the old butt link style factory chain. They're made for longevity and not so much performance although they do work well
Old Oct 28, 2011 | 12:40 PM
lt1-xjs's Avatar
92-94 requires the Cloyes C3228 set with the spline drive. Unless you have converted to the vented opti, then there are no options.
Old Oct 28, 2011 | 01:07 PM
mobileman's Avatar
If your wanting to use the stock pump you can use a new gm cam gear, cloyes oversized crank gear, and a cloyes replacement chain. This is what I used on my 355 and the cam timing was right on and the chain was tight like its suppose to be.
