383 Motor Failure. FML
NOPE. I noticed the crank pulley dancing around a bit, and shut it down. The pulley and the hub are both tight on the crank snout from what I can tell, but I can move the pulley itself up and down about 1/8 of an inch. I'm guessing that one or more mains is gone or spun. Other than the rattle, and the nasty rattle/grind when shutting the car down, everything else was fine. Oil pressure is great, the exhaust note seems normal, its not burning or leaking any fluids.
I'm guessing its going to at least need rod and main bearings and a crank......But I'm not even sure what parts I would need since I didnt build the motor. I found out that the previous owner of the car that the motor was bought from right here on LS1 tech, and here is the ad:
https://ls1tech.com/forums/parts-cla...w-3-000-a.html
I'm just sick to my stomach right now....I'm hoping that the motor just needs a crank and bearings, but so far my luck hasn't been that great. Any suggestions?
Oh yeah, and I think the main cause of this failure was because the person who put the motor in put the stock weighted flexplate on it...and its an internally balanced motor. It shook the hell out of the motor for almost 2 years, until i bought it this spring. A few weeks ago, I put a balanced flexplate on it and it cleared up the vibration completely, but apparently it was too late.... damage done.
If mains did spin that can make a block not worth repairing, hope that is not the case just want you to be aware it is possible.
It was a motor built all on price and it showed in a short life. It sucks that you got burned rather than the guy who slapped together a POS in the first place.
Only way to know how bad it is is going to be to pull it apart, best case like you said is crank and bearings, good cleaning and that will require a rebalance too. Worst case would be spun mains and rods damaging the block and rods at which point all you have left is home ported heads, mediocre cam, intake and pistons.
Ive seen another one snap in half this year on a stroker engine. Eagle will leave you holding the bill even if its within warrenty.
EDIT: just read the forsale post...and it is an eagle crank! go ******* figure!
