racetronix fuel pump
Did you replace the fuel filter when you did the pump?
If not, then you may have to pull it back apart and make sure the line to the fuel pump is on fully and locked into place with the proper o-ring in it (or it will leak and bleed off pressure) and make sure that flexible line is also not kinked.
If you didn't do the filter, chance that first. If you still don't get proper pressure, then you have no choice but to pull it back apart.
