LT1 alternator question
I emailed the seller and it turns out he listed the auction incorrectly, and the alternator is actually off a LT1 vette.
Now he is telling me that I can unbolt the back of the alternator and rotate it 180 degrees to match the mounting points on my LT1. Is this true? Any cons from doing this compared to my alternator? Any pros over using a vette alternator?
Thanks!
An other thing to look for is the eyelet on the small end may be threaded, not a thru hole like the stock alternator. If that is the case then you will have to drill it out to use the stock bolt.
Thanks
I got the right alternator this time, but I noticed that my old alternator has a bolt on the backside where the positive side of the battery is grounded to; the new one doesn't have this bolt.
Is is possible to take the bolt off my old one or ground that connection elsewhere?
Thanks.
If that is missing you got an improper rebuilt alternator.
It is a stud that needs to be bolted from the inside. It is a special stud as it is square on the inside where it fits into the positive side of the bridge rectifier (and also connects to the regulator internally).
Send it back and have they give you a properly built unit.
I tried buying it off ebay and got the second one here off tech to save some money but if i cant get this one working then ima just go ahead and get one from NAPA or something.
