where to buy motor
Old Mar 26, 2012 | 07:14 PM
  #61
98gtp's Avatar
at this point im just looking for stock to 400hp(if that)
Old Mar 26, 2012 | 07:19 PM
  #62
lt4388stroker's Avatar
Originally Posted by RamAir95TA
Good option if you're okay with shoddy workmanship and budget parts.
haha i seen there heads make big power, never seen nobody with a complete engine from them but hey someone has to buy one and tell us haha
Old Mar 26, 2012 | 07:23 PM
  #63
RamAir95TA's Avatar
That's a 125HP range.
Perhaps you should figure out what you want first before you start looking for advice...AGAIN.
Old Mar 26, 2012 | 07:24 PM
  #64
RamAir95TA's Avatar
Since when does Golen's heads make big power?
  #65
98gtp's Avatar
a reman or rebuilt lt1 is over $4000?
Old Mar 26, 2012 | 07:27 PM
  #66
RamAir95TA's Avatar
You said you wanted 500HP. Now you want stock.
FIGURE OUT WHAT YOU WANT.
Old Mar 26, 2012 | 07:29 PM
  #67
98gtp's Avatar
look top of this page. at this point im just looking for stock to 400hp(if that). not really picky at this point
Old Mar 26, 2012 | 07:33 PM
  #68
RamAir95TA's Avatar
Rebuilding your stock engine will cost you around $2000 using all stock parts.
Rebuilding your stock engine and adding the necessary parts to get 400fwhp will cost you $4000, minimum.
This would be so much easier if you weren't so wishy washy.
Old Mar 26, 2012 | 07:34 PM
  #69
cheeck out this link they did a head test
http://www.gmhightechperformance.com...n/viewall.html
Old Mar 26, 2012 | 07:37 PM
  #70
ZO7 Josh's Avatar
Golden engines
Old Mar 26, 2012 | 07:42 PM
  #71
RamAir95TA's Avatar
Not this crap again. That article cracks me up every time someone links to it.
Old Mar 26, 2012 | 07:44 PM
  #72
haha thats the only one i found whats wrong with it
Old Mar 27, 2012 | 07:25 AM
  #73
SS RRR's Avatar
Village Troll
Kinda like the one with a LT4 hotcam and stock heads making 425hp or some mess?
It's a fluff piece. Pretty much you shouldn't believe everything you read. Flow numbers are a lot like dyno numbers...
Old Mar 27, 2012 | 08:04 AM
  #74
96capricemgr's Avatar
Golen has a "happy" dyno and is about the only place posting engine dyno numbers for LT1s. Even folks foolish enough to like Golen will admit their engine dyno to chassis dyno losses are 25% which is a bigger number than it would be on an honest engine dyno.
One of the Impala guys had issues after just a few thousand miles, when the opened it up they found a rodbolt crossthreaded the whole way. About the only explanation for that would be assembling the shortblock with air tools.
A stroker that barely manages 500fwhp is sad, I think a lot of you would be shocked at what a good heads/cam setup would make tested the same way.
Choosing one timing setting invalidated the whole test, different chambers are going to want different timing and 38 degrees is a lot for a modern efficient chamber. They probably figured out what head they wanted to shine and optimized on that to stack the "results".
This is all besides the recent 490+rwhp results we have seen from the AI ported 21 degree Trickflow with a hydraulic cam. A good setup making at the wheels what most of that did at the flywheel on a happy dyno.
Old Mar 27, 2012 | 09:12 PM
  #75
98gtp's Avatar
There's a company by me called Jasper and they sell remanf. engines. Total it would be $3500 labor incl and take two days
Old Mar 27, 2012 | 09:21 PM
  #76
merim123's Avatar
Don't take this the wrong way, but you have gotten advice from some of the fastest LT1 guys around and you throw that to the wind with catalog links and marketing you read. If you don't trust the advice here, you should go down to Jasper and get a warranty and get your stock car back on the road. If you're willing to wrench and take some advice from people that have dropped 10x your 4k budget, you may get something decent you can enjoy from their experience.
Old Mar 27, 2012 | 09:30 PM
  #77
98gtp's Avatar
The thing is I do wanna do alot of work to my car n im actually still messaging some of the people that gave me advice but I have 150k+ miles on trans and rearend. I just got laid off so i cnt spend as much as I would like. And I dnt wanna build up the motor so much that the trans goes or blow the rearend.
Old Mar 27, 2012 | 10:11 PM
  #78
Junkyard engine, install it yourself.
I would buy a used engine before Golen or Jasper. If you buy a junkyard b-body engine chances are decent it did not see a lot of high rpm abuse and they are cheaper.
By Brett Foote | 2026-06-04 05:00:17
