Got a real issue with gas
Old Mar 6, 2012 | 11:31 AM
thegreatwhite1994's Avatar
Default Got a real issue with gas
Hey guys, I'm getting about 110-150 miles on a full tank of gas. I got an A4, full bolt on. Not sure if its tuned or not but i get the smell of gas sometimes through the vents or outside of the car. Can anyone loan a hand or some insight? im at kind of a loss
Old Mar 6, 2012 | 01:05 PM
69gto96z's Avatar
Is it bogging down or blowing black smoke? Check the connection to the MAF is good, and that the connection to the coolant sensor and that the coolant sensor on the waterpump are good.
Old Mar 6, 2012 | 01:27 PM
GreenBlood55's Avatar
They make meds for that.. Beano,gas-x.....
Old Mar 6, 2012 | 01:50 PM
69gto could you be more specific of the bogging down? i pulled a code for the MAF but i checked it out and it all looked good
Old Mar 6, 2012 | 02:06 PM
guppymech's Avatar
If your O2 sensors have over 100k on them they should be replaced. As they get old they drift rich. Some people say to lightly tap on the MAF sensor with the engine running, if the engine stumbles the MAF is bad. I've never needed to try this test though so don't know for sure.
Old Mar 6, 2012 | 02:13 PM
my stepfather recommended the maf test and we hit it pretty decent with a flashlight that wasnt the issue. i had a hunch about the 02 sensors are they hard to reach? im gonna see if i can pick 2 bad boys up. would that be the cause of the car stinking like gas and getting horrid mpg?
Old Mar 6, 2012 | 02:16 PM
iTh3 Riddler's Avatar
If its running rich then yes it would
Old Mar 6, 2012 | 03:01 PM
69gto96z's Avatar
You hit your MAF with a flashlight?
If the car is throwing a code for the MAF, the problem will probably be MAf related. Does the pigtail connector look to be in decent shape where it makes contact with the connector pins?
Old Mar 6, 2012 | 04:01 PM
yes the maf itself looks brand new and all connectors have good looking pins. i appologize for acting like a redneck... good god i sounded like joe dirt
Old Mar 6, 2012 | 04:11 PM
slomarao's Avatar
did you just buy this car?? any other history about it?? more info would help us help u
Old Mar 6, 2012 | 04:40 PM
i bought the car used about a year ago its always ran rich. the dealer (yeah i know) didnt know anything about the car history or otherwise. i tried looking for the original owner but to no avail.
Old Mar 6, 2012 | 05:53 PM
69gto96z's Avatar
Was the code for the MAF the only one it was throwing? I had a problem very similar to yours years back, I put new o2 sensors in, which did nothing. My problem ended up being a bad pigtail on the engine coolant temp sensor in the waterpump.
Old Mar 6, 2012 | 06:47 PM
im pulling an ac code but i bought it without ac... thats a story for another day though. i know during the summer i get the coolant light even if the radiator is topped off.. and it likes to overheat too
Old Mar 6, 2012 | 06:57 PM
69gto96z's Avatar
Don't worry about the coolant light, those sensors are junk. When it overheats, does it blow back out of the overflow tank? Also, I would check out the coolant sensor on the water pump. It is a factor when the computer is determining the AF ratio. I do not know whether OBDI will throw a code for it or not, all I have ever owned is an OBDII car. But if the car is complaining about the MAF, there is probably something going on there.
Old Mar 6, 2012 | 07:01 PM
zraffz's Avatar
When you open the gas cap, does it hiss?
Also, is your cat clogged?
Old Mar 6, 2012 | 07:24 PM
zraffz yes the cap hisses like a pissed off rattler.
and yeah gto thats exactly what it does why the hell does the coolant go everywhere
Old Mar 6, 2012 | 08:38 PM
zraffz's Avatar
Well for one your charcoal canister is clogged or a return line is clogged. It's pretty common since the charcoal cans only have a shelf life of a few years on a DD. You can rather find a gas cap that fits the threading with a vent built into it (since the LT1 cars have a charcoal can they don't have vented caps) or replace the charcoal can... I'd just get a vented cap and see if that fixes it.
Poor fuel mileage can be a bunch of things. What gears do you have? What do your plugs look like? Do you have anyway to read the O2 sensors? How do your O2 sensors look? How does the car idle? Does it feel sluggish/down on power?
An improperly vented system can cause it to run funny but it isn't causing that kind of fuel mileage.
Old Mar 6, 2012 | 09:27 PM
im sure i have either 3.23s or 3.73s i dont think it would cause 8 mpg tho. plugs are brand new forget the brand but they were high performance ones, im looking into the o2s because the readings when i read them werent too consistant, one was reading the normal the other was in a much shorter range (shoulda wrote this down sorry). and the idle on a cold start oil pressure is super high as is voltage until it warms up. then the idle drops so low the car doesnt move unless i give it gas. the volt meter drops and the oil pressure. and its kind of a rough idle.. its hard to explain without seeing but its deffinatly sluggish unless i jump on it.
Old Mar 6, 2012 | 09:35 PM
KyleW707's Avatar
Change the coolant temp sensor in the water pump. I had the same symptoms, and a Made code, changed the sensor and fixed it,including the MAF code.
Old Mar 6, 2012 | 10:07 PM
ill look into the coolant temp sensor and o2s this week/weekend. my guess is the water pump isnt easy to reach considering i just had the dreaded opti issue 2 months ago
