Trick Flow Heads CC after Milling
Old Nov 30, 2011 | 09:17 AM
Mystery Bird's Avatar
Default Trick Flow Heads CC after Milling
Does anyone know what the CC's would be after milling the heads say .010 or .020? They are Trick Flow 23 heads with the 62cc's. I've searched around and can't find a definitive answer.
Old Nov 30, 2011 | 09:27 AM
Puck's Avatar
SBC heads typically lose 1cc per .006-.008" milled, so you will only drop somewhere between 2 and 3 CCs.
Old Mar 14, 2012 | 11:50 AM
You nailed it, had them milled .020 and it dropped them 3 CCs.
