Lt1 budget of 3000
Check out this http://elliottsportworks.com/
$3,000 can get you far or it can get you nowhere; it all depends on many factors.
For instance, my street car (locally driven) is a 1994 Z28 (automatic) with a rebuilt 350 (stock heads/cam/compression). All it has is headers-back exhaust, cold air intake and 4.56 gears in the rear. It is extremely snappy up until about 100 MPH... plenty fast for the street. Spins those 11" tires at 40+ MPH and accelerates very hard (like 0-75 in the 7 second range). It's no slouch on the street and can hang with some pretty mean cars. Looking into a mild cam (around 226/232 .578"/.574") and a 2,500ish converter. It should make the car a bit quicker and still keep her under the $3,000 budget from start to finish.
On the other hand my 6 speed trans am is torn apart. To the day I have over $6,500 invested into it (including initial purchase for $3,500) and still have nothing special. This winter the motor is off to the machine shop for an overbore. Budgeting $2,800 into a short block 355 that I plan on throwing LE2 heads/cam behind along with a 100 shot.
Auto- stall(3600+), headers, 1.6 rr, gears, throttle body, tune...
6speed- same as auto..... except clutch instead of stall.
THEN heads/cam can be thought about... plus, the supporting mods are HIGHLY RECOMMENDED before H/C...
wont get around 400hp until heads/cam but with supporting mods it should be a completely different car.
I would also say do what was said before, get it checked out and make sure that it is in good running order.
Also, we need full stats on your car before anyone could help you, you have yet to mention trans you have.
Suspension also goes along way, with these car.
Suspension, tires, 1.6rr, headers, tq converter, intake and exhaust
