Nitrous ring gap?
Old Dec 5, 2011 | 05:54 PM
bowtiedad_z28's Avatar
Default Nitrous ring gap?
What ring gaps are you guys running for nitrous?
Old Dec 5, 2011 | 06:04 PM
stevo9389's Avatar
stock for about 150 to 180 shot
Old Dec 5, 2011 | 06:24 PM
TwoFast4Lv's Avatar
Mine is at 28 and 32 Just a little two stage bump out of the hole
Old Dec 5, 2011 | 06:52 PM
Anybody else care to share their nitrous ring gaps?
Old Dec 6, 2011 | 01:34 AM
gregrob's Avatar
Old Dec 7, 2011 | 08:48 PM
Wyocattech's Avatar
Old Dec 7, 2011 | 09:30 PM
1963SS's Avatar
I've built several NOX engines and I've always used .024, .026, .015 and have not had any problems. These guys seem to be running a bit looser than that. Heck, I've built some small block Poker Run Marine engines and use the .030 gap. That seems way big for a NOX engine. The Poker Run boats run 5500-6000 rpm for quite a while.
Old Dec 7, 2011 | 10:01 PM
gregrob's Avatar
First, WTF is a "NOX" engine.
Second, it would seem you're inferring the ring gap on a NITROUS engine should be smaller than N/A?
.030 is fine for a big shot. It was right in line with my builder AND piston manufacturers recommendation.
Old Dec 7, 2011 | 11:48 PM
6oh-goat's Avatar
maybe he meant NOS?
Old Dec 8, 2011 | 06:46 AM
Nostang's Avatar
.026/.023 for up to a 250 shot.
Old Dec 8, 2011 | 09:37 AM
1963SS's Avatar
maybe he meant NOS?
I did mean NOS. Sorry, I've been working with a guy to get his engine to meet emissions. He has a different cam and I've been playing with the EGR functionality to reduce some NOX emissions. I guess I had NOX on the brain.
Also, I didn't intend to talk about your builder. There are many of us out there and not all do things exactly the same way. I use a lot of Mahle and Diamond pistons and they specify .055 for Mahle and .070 (Diamond) per inch of bore for a NOS equipped engine. That works out to about .022 top ring gap (Mahle) or about .028 for the Diamond which I think is too much. I open up the Mahle and close down the Diamond. We're all different.
I typically open the second ring up a couple of thousandths more than the top ring. Any combustion pressure that gets through the top ring gap shouldn't pressurize the piston area between the top two rings. That will create a pressurized area and could lead to a flutter of the top ring and decrease it's sealing properties. My making the #2 ring gap a little bigger it allows this pressure to escape instead of build.
Sorry if I offended you or your builder. It certainly wasn't my intent. As I said, we all do things a little differently. Not right or wrong.....just different. I plateau hone every engine and don't suffer as much initial wear and probably have less initial oil contamination than people that just do quickie 220 grit hone. Again....not necessarily wrong, just different. If the rings don't wear initially then the gap should be closer to what is necessary after a bunch of miles. But that's just me.
Old Dec 8, 2011 | 01:32 PM
WS Sick's Avatar
I was thinking you were using a different nomenclature for Nitrous OXcide...lol and just left it at that.
Old Dec 8, 2011 | 03:11 PM
1963SS's Avatar
Nah, nothing that fancy at all. Just a brain fart. I've been working with Nitrogen Oxide emissions stuff and somehow the old brain crossed Nitrogen and Nitrous. Remember the old saying about alcohol and brain cells dying........it must be true.
Just sitting here waiting to eat humble pie.
Old Dec 8, 2011 | 03:46 PM
Thanks guys. It looks as if everyone is running totally different set ups. I should have specified for a 383. My builder has gaps in mind i just wanted to see what other 383's were running.
Old Dec 9, 2011 | 02:35 PM
TwoFast4Lv's Avatar
My gaps are set up on a 383running 14 to 1 and hitting it with 400+
Old Dec 9, 2011 | 03:04 PM
95 TA - The Beast's Avatar
There are far too many variables you have not specified to give an accurate reply.
What are the pistons/rings/bore/stroke/cr/etc???
Just check with the ring and piston manufacturers of what you have and see what they say for your application.
