24x ????
Old Dec 10, 2011 | 01:45 PM
andrew ws6's Avatar
Default 24x ????
I have a 96 T/A and am thinking about going to the 24x set up, I am going to be going to the local pull a part and scavaging tomorow and was wanting to know what I could get the pcm and coils out of and any other parts I need to look for to help keep the cost down.
Thanks
Andrew
Old Dec 10, 2011 | 02:57 PM
95mysticta's Avatar
Truck Coils - Smaller, Hotter Spark, and Cheaper
Truck Plug Wires - They are longer so if you mount them to your valve covers it will give you some slack to get you running and upgrade down the road.
Coil Harness's - Make sure you cut the other side of the harness so you have both sides of the connectors!
PCM - 411 is most common.
PCM Bracket Tray.
Old Dec 10, 2011 | 04:15 PM
lethal bird's Avatar
I didnt realize truck plug wires were longer?
Old Dec 10, 2011 | 05:27 PM
andrew ws6's Avatar
is the 411 ppcm found in the trucks also
Old Dec 11, 2011 | 04:34 AM
95mysticta's Avatar
From what ive read and i could be totally wrong so correct me if i am the truck wires are supposed to be longer. As for the PCM im not totally sure im new to the LSx world but im pretty sure the 411 pcm was a 01-02 Fbody PCM.
Old Dec 11, 2011 | 09:46 AM
355z28's Avatar
most 2001-2002 trucks had the 411 pcm, also the plug wires would have to come from that year range as well. In 2003+ they changed coil styles and started using a shorter plug wire on the trucks.
