Are heads worth the money?
I have: LE 226/232 .592/.592 110lsa (w/ 1.6rr's)
From Lloyd's Website
LT1 LE2 heads consist of :
Manley 2.00/1.56 6000 series valves
Patriot Gold Extreme springs (155 lbs seat and 400 lbs open)
Steel retainers and locks
205 cc intake port
milling, cleaning and assembly
flow about 275/190 CFM
assembled and ready to bolt on!
$1300 for LT1 LE2 heads.
Nitrous is by far the best bang for you buck. Keep in mind a complete Quality nitrous kit will cost around 900-1200.
I dont think you will be disapointed in the Heads. Plus the heads are only going to run you around $1050.00 You already have the springs, locks and retainers for your cam.
You may think $1000.00 is a lot for 40 horsepower, but this will be throughout the curve and feel like much more. Its something that will have to be done eventually. I would run the cheaper 5716 Mr. Gasket head gaskets with them.
This info might help OP too... Does anything need to be done to the fuel system? Im wondering if the LS6 vette injectors would work if bigger injectors are needed, those engines were what 405hp? 28lb injectors i think?
What HP are the stock injectors good to?
The cam looks good, imo. Last edited by BOLO; Dec 25, 2011 at 02:54 PM.
Rob94hawk, what is your set-up if you don't mind sharing?
On last question; What should I do about the intake? Port match? Who does that or can you buy them?
Thanks ahead!!
Thanks ahead!!
