injectors?
Old Jan 9, 2012 | 08:54 PM
TravisMcGill2000's Avatar
Default injectors?
What size injectors do yall guys think i need. New motor is a 355 with le trickflows ported ibtake, 236/244 cam, and will b spinning to 7k. I currently got 30lb svos. Should i go 36 or 42s. Thanks
Old Jan 9, 2012 | 09:26 PM
RamAir95TA's Avatar
42#s will allow you some room to grow. I run 42#s in my motor with a similarly-sized cam.
Old Jan 9, 2012 | 09:31 PM
lt1slowz28's Avatar
go bigger if you can.. allows room for growth later
42#'s will be fine
Old Jan 10, 2012 | 07:00 AM
moehorsepower's Avatar
^^ What he says..
Old Jan 10, 2012 | 08:20 AM
flyinZ's Avatar
Same here, 42#'s.
Old Jan 10, 2012 | 06:20 PM
GIZMO's Avatar
The 30´s are the biggest that you should run (N/A). 24´s would probably be faster if you crank the fuel pressure up a little. The idea that you ¨grow¨into injectors is dumb. Any motor requires X amount of fuel. Upgrade the injectors when you build more motor (a lot more motor N/A).
Old Jan 10, 2012 | 07:08 PM
flyinZ's Avatar
If he is still going to run nitrous, Id still stick with the 42#'s.
Old Jan 10, 2012 | 07:13 PM
Plan on sprayin 200+
Old Jan 10, 2012 | 07:45 PM
05HD's Avatar
What, dry?
Old Jan 10, 2012 | 07:57 PM
defaultexistence's Avatar
42# and twin pumps
Old Jan 10, 2012 | 09:03 PM
BOLO's Avatar
Very interesting point there. So, will the 30#'s still be good for a 383 motor N/A?
Old Jan 10, 2012 | 10:02 PM
No will b wet with 1gallon with c16. Sorry should have said that earlier. So if im sprayin a wet shot can i stick with the 30s gizmo?
Old Jan 11, 2012 | 06:30 AM
bowtienut's Avatar
Only one person in this thread up to to now has given you the right advice. GIZMO has it right.
I make 425 SAE with 30 lb SVO's, stock fuel pressure, plenty of headroom. It has nothing to do with how high you spin it.
If your 200 shot will be a wet kit, the 30 lb injectors you already have are what you should stay with.
Old Jan 11, 2012 | 06:32 AM
bowtienut's Avatar
Yes, we're making over 500 rwhp NA over here with 30 lb SVO's.
Old Jan 11, 2012 | 07:50 AM
BIGCAT7274's Avatar
What's the duty cycle on what you have?
Old Jan 11, 2012 | 08:10 AM
95mysticta's Avatar
Im running Accel 30lbs with my setup at 88% duty and mine aint no 425rwhp beast.
Old Jan 11, 2012 | 09:19 AM
05HD's Avatar
I'm having a hard time with this in my head. Can you explain how smaller injectors make the car faster? Only thing I can come up with is something was missing in the tune for the bigger ones.
Old Jan 11, 2012 | 09:37 AM
draggin97s10's Avatar
yes because the spray pattern is better with the properly sized injector. Check through gizmos threads when the switched to a smaller injector and pick up a tenth or two
Old Jan 11, 2012 | 09:42 AM
05HD's Avatar
If that is the case, our stock injectors and SVO 30s are both ancient designs. A bigger, newer injector would atomize better even at 1/2 the pulse width plus have a much better chance of getting all of the fuel in while the intake valve is open.
Old Jan 11, 2012 | 09:44 AM
SS RRR's Avatar
Village Troll
One rule of thumb suggestion for minimum injector size is to multiply projected flywheel HP X .07.
