Ok im slow but please help me understand Shbox's picture
Old 01-11-2012, 09:01 PM
GMC5.3's Avatar
Default Ok im slow but please help me understand Shbox's picture
So bascially i can turn the cam dowel pin slot to either 1 or 6 on the opti and see where the pin just slides in? Sorry guys id rather be safe than sorry
Old 01-11-2012, 09:12 PM
Jpack's Avatar
Rotate the backside of the opti to where ever the cam dowel pin is and slide it on. The cam doesn't have to be at #1 or #6 tdc.
Old 01-11-2012, 09:14 PM
shbox's Avatar
Those are just reference marks. When the hub pointer is at 12 o'clock, it will be at 1 or 6 TDC. The dowel pin will be in the coinciding location. It is to help you put the opti in the right position before sliding it on. The whole thing is pretty much self-explanatory.
Old 01-11-2012, 09:42 PM
GMC5.3's Avatar
ok maybe im just stressing myself out, this is just a very important job and im not screwing it up with such an expensive part. Do i need a special tool to take the opti screws out to apply Loctite?
Old 01-11-2012, 10:44 PM
shbox's Avatar
It is a very small torx. I can't remember the size just now.
Old 01-12-2012, 02:13 AM
Zlow28's Avatar
once you put the opti back on, it might take you a while to get it to align. It took me a good 10 minutes or more cus i felt it kept spinning on me.
Old 01-12-2012, 11:30 AM
brettmc's Avatar
after you put the opti on, make sure it is completely flat against the timing cover BEFORE tightening the opti bolts. after you put the opti on, make sure it is completely flat against the timing cover BEFORE tightening the opti bolts.
notice i said that twice. It is VERY IMPORTANT!
after the opti bolts are tight, push on the opti harness connector. make sure it clicks into place. if it doesn't, figure out why. if you can't figure out why, the plug is most likely damaged. replace it with an opti harness pigtail and solder it in.
Old 01-12-2012, 12:23 PM
SilverSS07's Avatar
I think the rotor screws were a t8.
Old 01-12-2012, 12:48 PM
69gto96z's Avatar
Take the front cover off when you install the opti, this will allow you to hold the shaft and keep it from rotating. Then put the cover on once the opti is bolted in place.
Old 01-12-2012, 12:52 PM
leadfoot4's Avatar
Right off the top of my head, I actually think it's a T-4. I know whatever size it is, I had to do a bit of scrounging in order to find one to buy...
Old 01-12-2012, 11:47 PM
GMC5.3's Avatar
we are talking the front cover of the opti correct?
Old 01-13-2012, 06:58 AM
shbox's Avatar
He's talking about the cap. That way you can see the rotor and know the position.
Old 01-13-2012, 12:06 PM
GMC5.3's Avatar
ok thanks everyone for the help, hopefully ill be posting pics for you guys, of a pc detail if i can get this z running safe.
Old 01-13-2012, 01:56 PM
kissrocker1200's Avatar
Northern Industrial Tools
5 bucks, set of like 10
Old 01-15-2012, 01:50 PM
GMC5.3's Avatar
so i got the old distributor off, took the new opti cap off so i could make sure it goes into the dowel slot and my new opti doesnt slide in? I shouldnt have to force it right? am i missing anything here
Old 01-15-2012, 01:58 PM
shbox's Avatar
Put a little lube on the o-rings that fit into the cam nose. It'll be snug.
Old 01-15-2012, 08:07 PM
GMC5.3's Avatar
got it thank you, how big of a problem am i going to have if the damn opti harness clip broke off, anything i can do?
Old 01-16-2012, 05:44 AM
leadfoot4's Avatar
I would think that AC Delco would offer a replacement part. They do offer all sorts of harness bits and pieces.
Old 01-16-2012, 07:28 AM
shbox's Avatar
Go to eficonnection and buy a new harness. The GM one is terribly expensive in comparison.
Old 01-16-2012, 11:09 AM
GMC5.3's Avatar
and last, can someone please tell me what color the water pump electrical connector is, seem to have misplaced it, thanks again everyone and shbox for your patience
Quick Reply: Ok im slow but please help me understand Shbox's picture
