Comp cam 503
Torque converter the car would probably drive with the stock one but at the track I bet the cam wouldn't make the car any faster you really do need to do a decent stall with it a 9.5" unit absolute minimum stall in those is 2800 but most guys are happy with the drivability of even 32-3400 on mild street cars, a lot of heads/cam guys go 36-4000. Just buy a good converter I feel comfortable recommending Edge Yank and Vigilante. Yank might be the best of those three, Edge has always worked great for me and is a few hundred dollars cheaper because it has a stamped cover where the other two are billet. There are definitely some bad brands out there too so if you consider something you can't find info here on ASK first.
The last 3 converters I have had in my car were Edge or restalled Edge, liked them all just kept changing the car around them hence one replacement and then a restall. Been very happy Andre is great to work with, at the same time I would like to try a Yank once as I think the car would MPH a little better.
Dwayne is spot on with the intake manifold info.
-Dustin-
I haven't use a Revmax and haven't seen a lot of people use them, but those that I have seen ended up not happy.
Often times people are happy with things simply because they don't know any better.
I have experience with all but edge and for anyone on a budget I would not hesitate to recommend revmax. Vig and yank are good products but their cost compared to the value of these cars make them harder to justify.
Often times people discourage the use of a product because they don't know any better.
I remember when pacesetter long tubes were complete crap, then people started using them.
That being said its been down the track 20-30 times and was daily drivin befor the cam swap. and it hasnt blown up or anything yet. I didnt send it anywhere to get checked out, i just put it in the car. And i didnt know anything about the owner that i bought it from.
that being said.... I wish i got a different converter. Somethings will just sit in the back of your head, wondering when its gonna happen...My TCI converter blowing up is one of the things i always think about. Any converter can go bad though, installation is key.
I would get a yank. I was on a tight budget back then and just wanted a stall. Now i wish i wouldve saved up for another month or 2 and gotten a yank 3200 or 3600.
