Quick, Still Street Legal LT1's
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Just kind of curious what kind of builds are out there that are still street legal. This will be my main goal whenever I decide to do an LT1 build, and it probably wont be for a few years but I want to get a much info as possible before I buy it! Anyways I know this topic is extremely broad, but I thought id ask anyways.
-Mike
-Mike
define "street legal"
Many of us do not have to deal with any inspection and therefore get away with high overlap cams and such, but in a state with tailpipe emissions tests that would not fly due to high HC emissions.
Even just passing a tailpipe test might not fit the strictest definition of "legal" because a lot of good performance parts that do not hurt emissions also do not pay the bribe to CARB for an exemption number.
The comes the question of NA/boost/nitrous.
With boost you could just turn up the boost number and keep making more power without hurting low speed emissions but the CARB approved kits will have small blowers.
Well, street legal as in able to drive it on the streets. I want it to still be drivable to a point, pass emissions and safety ect. I was thinking the easiest way to do this would be with an NA engine w/ N20 and just disconnect the N20 for daily driving.. Idk just spitballin here.
Yeah I wasnt meaning this to be super technical. But I do live in Canada, and need to pass emissions, safety and such. I guess ill need to keep the overlap to a minimum and run high compression. We will see, kind of a noob to this stuff, just trying to learn.
Yes I understand all of this fun stuff, Im training to be a mechanic and am currently in a 2 year program in College. As long as your tailpipe emissions are within specifications, It doesnt really matter where the heck the cat is. Mechanics arent that **** around here. Plus I could always just give myself an e-test...
As long as tail pipe emissions are within specifications, it doesnt matter what is going on with the car TBH.. That and i cant have a check engine light on,
yea my car being obd I........which isn't even in the car any more mind you lol......has to pass a sniffer here in RI......theres no way in hell i would even come close lol...espically with leaded fuel.....in other states with less strict laws id prob pass........brakes, lights all that is there but not here.......again have to check with your local laws and see what you can get away with......i know a guy so i still got plates and a sticker ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
dont get me wrong i still drive it here and there but it is kinda risky if i get pulled over in a town where i dont know anybody on duty....
hell look at florida dont even need a sticker!!!! that'd be easy!!
Moderator
http://para.noid.org/~lj/
This LT1 was passing CA emissions and running 9s, it would how ever be an emissions illegal set up in any state because it moved the driver side catalytic converter and as far as CA goes a YSi isn't likely to have a CARB compliance number issued with it. But it did hit 9s with an S trim. I also think the area far as internal modifications is a bit grey.
But just like what 96capricemgr and SS RRR are saying, way to many variables with a modified car. Really and truly it really comes down to what you can get away with more than any thing.
Got my car inspected at a place I never went before, guy puts it on a lift, and my LTs and ory couldn't be more visible. Not a single word lol other then my horn not working...
-Mike
-Mike
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
My car is obdI and only gets a visual inspection. Yeah I "know a guy" who will overlook emission stuff, as long as the glass is good, the lights and horn work, and the tires are good, he will pass it. I run mufflers, DOT Hoosiers and pump gas so it is streetable, and I take it out to cruise nights here and there. I'll drive it to my local 1/8th mile track that is 10 miles away.
Where exactly are you in Canada? Here in Ontario its very restrictive. If your looking at making the most power possible and still passing emissions then a super/turbo or nitrous build is what you need to look into. The only lt1 around here to legitly pass emissions with a 383 le2 h/c stalled auto and 12 bolt made 411rwhp. Its a pain in the *** trying to build a race motor and still pass the sniffer. My build for example makes 376/377 with that le cam and had some room to grow. I bet if I moved up to le's next biggest cam made on a 112lsa I'd be a lot closer to the 400rwhp mark fully compliant.
Oh, Im from Ontario too, I know its pretty bad.. Hopefully by the time I get my LT1 it will be 25 years old and doesnt need emissions anymore. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Scratch that... It needs to be pre 1987..
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
