New 383...working the bugs out
#42
So I figured I would update this thread with the solution to problem #3, the exhaust leak on the passenger side that the felpro's couldn't fix. The car sounds so much better now and I can drive it windows up without smelling like exhaust and gas
I got some Earl's "pressure master" graphite foil gaskets and they fixed my leak no problem
They are a bit pricy though but worth it when you see the high quality. We checked the header flange on a straight edge and it was flat...so in conclusion if you have terrible luck with exhaust leaks like I did; copper gaskets leaked, felpro's leaked; Earl's makes awesome header gaskets! ![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
http://www.summitracing.com/parts/EAR-29DA3BERL/
![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#43
Just to update the thread, all bugs have officially been fixed
The 80+ psi oil pressure the gauge was reading was due to a bad oil pressure switch/sending unit. I finally replaced the thing while my car was down for unrelated issues. I guess it got bumped during engine installation
This motor has tons of oil pressure...50-70psi while driving normal and 40 psi at idle. That about right for a high volume oil pump on a newly built bottom end?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#47
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#48
Its been my experience that if the ball in the blockis not installed (the one under the rear main cap, then pressure will be VERY low. Ask me how I know.
