New 383...working the bugs out
383 build going on 8 months now, exhaust is hooked up as of yesterday and it is drivable with a PCM for less tune; however I have some bugs/issues to work out before it gets inspected and dyno tuned and I'd like to hear some feedback on my concerns.1. Oil pressure seems unusually high....pins the gauge at 80 psi even at idle
2. I'm officially an electric waterpump hater now....I bought a lightly used Meziere electric waterpump and it either died or the mechanic who installed the motor didn't wire it up right
So the car gets up to 220 degrees within 2 mins of starting
Needless to say I can't drive it until this is fixed. It was tested before it was installed and worked fine....(does running one of these with no water for a couple seconds screw it up?) So if anybody has the wiring instructions to one of these let me know....I'm pretty pissed the mechanic didn't test the damn thing once installed....although part of that is my fault because the PCM wasn't tuned at the time the motor was done so it was not run to operating temp until recently, he only started it for 30 secs or so when the motor was installed. 3. PITA leaky headers. Once again, I have a leak on my passenger side header between #4 and #6....what is a decent header gasket to use for a problem header?
4 Starter will BARELY turn this beast over....it's VERY slow turning the engine and drains the battery quickly. New OE starter or get a geared reduction aftermarket one? FYI...motor is only 11.5 compression
Constructive advice is appreciated.
as for the pump it can run waterless for a decent amount of time so that prob didn't do it.......wiring is a simple standard circuit through a relay that is triggered with ignition sw12 volts.......make sure the guts inside the pump are removed and not pressing on the snout of the EWP or it will kill it........
for a warped header flange or unflat exhaust surface on the head use remflex gaskets or fix the header
EWPs work just fine. Unfortunately what happened to yours is the risk you take when you buy used parts, especially electronic parts. My CSR has been running strong for 8 years.
What headers do you have? I've always liked the 1406s from Felpro.
2. It's possible the motor is weak, could spin on it's own, but cannot handle moving water. Meziere charges a flat rate of around $100 to have it rebuilt.
No pics anymore, but here's the gist of how to wire it:
http://www.ws6.com/kelley-wp.htm
Wiring the pump using a relay and direct source off the battery is far better than relying on a circuit not meant for the load the pump would demand.
3. The flange on the header may be warped. As RA stated, 1406's are the bombdiggity.
....although the hoses radiator don't get that hot. You should be able to hear the WP whining/buzzing/whatever when you turn the key to the on position to prime the fuel pump (not starting) correct? (I am an electric WP newb). The guy I bought the WP from already installed in in the WP housing and had used it with no issues before FWIW. The Best V8 Stories One Small Block at Time
*See original post....added issue #4 with the starter
Water pump- Run direct 12v and ground, what happens?
Headers- Take the leaker off a put a straightedge on the flange, is it warped?
Starter- Does it only have a hard time when the engine is hot due to the water pump issue?
Hmmmm....just doing a little proactive research on this Meziere electric WP and stumbled across the product info sheet on their website. http://www.meziere.com/images/produc...tion/WP118.pdf
It seems these WP's have a 20 amp fuse included in the wiring harness; maybe the fuse got blown when I had to jump start the car once due to the starter draining the battery? I'll try to find this fuse when I get home. The sheet also mentions the pump should be able to be run dry for a few seconds, so I doubt that killed it. Looks like the wiring should be pretty straight forward.
http://www.meziere.com/ps-419-389-wik346.aspx
To get to it, I removed the fuse box from it's holder. There a plastic "pressure clip" on the bottom that you can press, and it will slide out towards the passenger side. Once you have it out, you can open the back cover easily. I used a simple splicer connector on mine to hook it in.
Barry Grant Relay
It's the same thing as the Meziere relay yet cheaper.
Take it FWIW.
On the starter problem, first, visually check the cable connections for a poor contact. If that checks out, do a physical check (wiggle the cable connections and see if anything moves). Next, check battery voltage across the terminals. It should be 12.6v or better. If it isn't, replace or recharge and test the battery. Once that checks out, do a voltage drop test by installing a voltmeter from the + terminal on the battery to the + terminal on the starter. Have an assistant crank it while you watch the voltmeter. Do the same with the negative side. If either side shows more than 3 volts, replace the cable. After all of that checks out and it still starts like ****, replace the starter with an LT4 unit from the stealership. After that, if it still doesn't start right, it is time to eat a 12 guage because your shiny new engine is partially seized.
And this is what the link says regarding using a relay:
And here it is:
Barry Grant Relay
Take it FWIW.
