Fan switch mod questions
3 resistors
http://www.radioshack.com/product/in...ductId=2062313
Toggle switch
http://www.radioshack.com/product/in...ductId=2062506
and does the wire matter?
Am i able to just splice in since i dont know how to solder, i read in some past searches about wire taps? Would this be an option?
Last i dont quite understand the led lingo based off of shoeboxs diagram, i barely understand some of it
Thanks for your patience
I tapped the high and low speed into a cheap switch from autozone, then ran another wire from the switch to a ground on the chassis... simple and it works flawlessly.
I'm with slowz28... I'll save the extra $45 any day for 20 minutes of research.
Finding wire that is the same size as wires your tapping in to would probably be optimal.
I've never seen one of those before, but it seems like it should work.
What exactly are you not understanding? This will help us help you.
Sorry for the double post, forgot to reply to questions in the last message lol..
this is a picture of how i wire tapped the high and low speed wires
this is how i wired my switch , hopefully you can understand but i placed it the same way i viewed the diagram in my 1st post
this is how i wired my high speed fan
this is how i wired my low speed fan
i dont know if its worth mentioning but for my ground i connected the far left two (top and bottom) and the bottom right together to complete my ground. My resistors are 470ohm 1/2 watt 5% tolerance
all your effectivly doing is grounding the different leads that are normally controlled by the computer.
grounding the green wire turns on the control relay for the low speed fans
grounding both the green and the blue turns on the high speed fans.
start with your meter on the ohm setting and touch the two leads together, the ohm reading should be 0 or close to it depending upon the sensitivity of the meter. regardless of reading, we only really need the touching reading (electrical continuity) and the not touching reading( not electrically continuous)
put one lead on a good ground, the outside of the cigarette lighter is what i use, and test the leads of the wires that you intentionally grounded, there are 3 at the switch.
with the switch in the off (middle) position, test the top left, lower left, and lower right terminal of the switch to ground as you have it pictured above. you should read continuity, if not fix it.
now put the switch in the low speed position (switch to the side with the single connection on the right as pictured) and you should read ground on the middle lower terminal. if not fix it
now switch to the high speed setting and test the lower middle and upper middle terminals to ground. if you have ground on both middle terminals you should be good to go inside the car.
now move under the hood and unplug your haness you have spliced into. with one test lead on the ground battery terminal, the other lead stuck in the end of the connector, test the green wire to ground, and the blue wire to ground. somewhere there is a bad connection and youll find it.
inside the engine bay your meter will read higher resistance to ground as compared to inside the car, do nto worry this is normal as the resistors you put in are causing the spike in resistance.
if everything tests out, i believe you have spliced into the wrong harness, if you dont get a ground where your supposed to, you have a bad connection.
for the connections at the switch, use a good crimping tool such as this one and use the same style terminal connectors you currently have. its tough to see the crimps in the pic, but the tool below is what i use.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
brand isnt that important, klein makes very nice tools, but i know channel locks makes a good set too at less cost for a one time use tool. use the part with the tit to make the crimp.
as far as the ratings on the resistors, i leave that to shbox and his website, he hasnt led anyone astray yet, so i trust it
also if you see copper showing, thats too much insulation stripped away, either cut it and try again, or tape it up. shrinkwrap the entire resistor, not just taping the ends up
The little dabs of tape and exposed bare wire are ok for testing, but you don't want to leave it like that. Nothing should be bare or showing anywhere.
Your parallel resistors can sit right next to each other. Just twist the legs together on each end, then connect that to the wire (like it's one resistor). Then cover the whole thing with heat shrink. Much neater that way.
