Lt1 cam choice for DD
A properly setup valve train will control XFI lobes and more aggressive with no issue. Like I said a lot of STREET lobes are more aggressive than the XFI but are still easily managed.
Now why dont you STFU and crawl back in your hole. Lay there and wait til someone else says something you can disagree with. It is ******* worthless when all someone EVER does is wait to pipe up about how wrong someone else is.
Why dont you try adding something useful to the discussion every now and then....?
It's a good thing .006-.050 lobe lift is the only part of the lobe that matters for aggressiveness
Part Number: 60121
Hydraulic roller, fair idle. Strong power increase in mildly modified engines with excellent throttle response. Will work with stock converter in 383 and up size engines or 2200 RPM stall speed converter in 305-350 cubic inch engines. Likes 3.23-3.73 rear gears. Also the largest cam for inboard/outboard marine applications.
Advertised Duration (Int/Exh): 270/278
Duration @ .050 (Int/Exh): 221/229
Gross Valve Lift (Int/Exh): .515/.530
LSA/ICL: 112/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-5800
Those might sound like stupid questions, but I don't know much about cams. I would like to know more because I might be interested in a mild cam some day.
On the other hand I have a hotcam for sale, $80 shipped OBO.
I also enjoyed my hotcam, trapped 110mph with it.
I think it's odd that some can run an XFI grind to 7000 rpm with older 918 springs and aftermarket heads with larger and heavier valves, and some cant rev past 6300 without loss of control of stock size valves. I'd be willing to bet that the more successful guys actually took the time to setup their valvetrain correctly, rather than just slapping it all together.
I think using crappy stock style pushrods is an issue as well - most have not seen spintrons of a valvetrain at even 6,000 rpms. Even with modest spring pressures the stock style PRs look like spaghetti and put all sorts of nasty harmonics in the valvetrain.
$50 summit special PRs aren't going to cut it.
Take the time to get the right springs, with the right size and length pushrods, and properly installed rockers, and you will have a much more rewarding combo then someone running the same cam without doing their homework and slapping everything together.
