Lt1 cam choice for DD
A properly setup valve train will control XFI lobes and more aggressive with no issue. Like I said a lot of STREET lobes are more aggressive than the XFI but are still easily managed.
Now why dont you STFU and crawl back in your hole. Lay there and wait til someone else says something you can disagree with. It is ******* worthless when all someone EVER does is wait to pipe up about how wrong someone else is.
Why dont you try adding something useful to the discussion every now and then....?
Which is why you should buy my brand new CompCam 306 cam for only $225on the parts section....hehehe...price to sell to! Should be enough to pull your brothers C5 and get you near the 370 mark, with the right components!! Got the new matching valve springs and injectors to compliment your LT-1 and I can give you a package deal for all parts. Let me know and good luck.
Ive always had the impression that higher lift will usually provide a higher duration, meaning more power through the powerband. But in this case, the duration is very similar.
BTW, CC503= 224/230, .503/.510 112lsa (for comparison)
Does the cam card tell you what the ICL is? If they attempted to match the 503, it will probably fall about 108, which is ok. If it were mine, I'd degree it and adjust it to a 104-106 ICL.
Simply put IMO, the engine wants more fuel in these areas where surge occurs and it is not possible to do this in a closed loop tune because the PCM will force an A/F ratio of 14.7.
Using an optimum tune, using 4.10s for a M6 application and adjusting your driving style just a bit will allow you to coexist with the surge that you get from these bigger cams. I have not run a 503 cam but referencing it against the specs of cams I have run, I would not expect the 503 to surge much at all. From what I have learned, overlap plays a large role in how much a cam will surge. Lastly like has already been said, A4 applications tend to absorb any surge that might be present.
